57
The Oneplus 3 "pocket problem"
  1. Anz19
    Cupcake Jul 4, 2016
    Anz19 , Jul 4, 2016 :
    I too noticed the same prob. I kept it in my pocket and after 1 hour i felt my phone warm due to which i had to take it out.
  2. truewt
    Cupcake Jul 4, 2016
  3. Ether
    Eclair Jul 4, 2016
    Ether , Jul 4, 2016 :
    Its a minor issue, and tbh the only issue I have come across with the phone. Its happened to me maybe once or twice only, its not a regular thing and its not insurmountable to resolve via a case if you really wanted to.
  4. Fraser
    Gingerbread Jul 4, 2016
    Fraser , Jul 4, 2016 :
    HydrogenOS has a setting, Pocket Mode, to deactivate the fingerprint reader and screen while in a pocket.
  5. tnttrx
    Froyo Jul 4, 2016
  6. tEf0o
    Jelly Bean Jul 4, 2016
    tEf0o , Jul 4, 2016 :
    Km
    Then bump leg against a corner or any thing hard = screen crack !
    Screen must be inwards in all pockets....
    Same issue must exist on all OnePlus units with finger print gizmo.
    Why it needs to be on back side of cellphone as solves problem partly.
    Same problem with OPO and the gesture thing, will start led light on it's own in pockets.
    As it's hardware that are running despite it is turned off.Expected.
  7. davidw16
    dfence likes this.
  8. bhanuteja200bc
    Honeycomb Jul 4, 2016
    bhanuteja200bc , Jul 4, 2016 :
    gravity box has a setting for this..proximity wakeup unlock option,that will fix this for rooted folks
  9. dfence
    Froyo Jul 4, 2016
  10. zeljko
    zeljko , Jul 4, 2016 :
    Hard reset solved it for me. No need for update or proximity sensor wizardry.
  11. toralex
    Donut Jul 4, 2016
  12. zeljko
    Just do the hard reset and it's fixed. Or wait for 3.2.0 in next two days.
  13. karlhendrix
    Honeycomb Jul 5, 2016
    karlhendrix , Jul 5, 2016 :
    I've experienced similar problem, after I turn gesture off it's getting a lot better, no more battery drain or constantly heat up (though sometimes I still feel my OP3 warm in my pocket).
    I'm running Oxygen 3.1.2
  14. dost4frnd
    Froyo Jul 5, 2016
    dost4frnd , Jul 5, 2016 :
    Really it solved the problem?
  15. dost4frnd
    Froyo Jul 5, 2016
    what exactly you did? did u loose all your installed apps and data? home screen settings and all? pls reply.
  16. maxxam23
    Ice Cream Sandwich Jul 5, 2016
    maxxam23 , Jul 5, 2016 :
    Yeah. I noticed that too. So I turned off ambient display & the issue was resolved.
  17. lupick
    Eclair Jul 5, 2016
    lupick , Jul 5, 2016 :
    I'm on 3.2.0 and problem isn't fixed
  18. alexferdean
    alexferdean , Jul 5, 2016 :
    What is hard reset? Factory reset? Or clear data and cache in recovery?
  19. Kragbell
    Eclair Jul 5, 2016
    Kragbell , Jul 5, 2016 :
    I'm seeing this problem but so far not lost to much battery. May try the cache clear and reset.
  20. zeljko
    Gingerbread Jul 5, 2016
