[Submitted] The phone does not reconnect to wifi without internet connection
  1. YaronShlomo
    Cupcake Sep 12, 2021
    YaronShlomo , Sep 12, 2021 :
    1. Connect to camera wifi access point
    2. Tap on notification "SSID has no internet access Tap for options,"
    3. select the "Don't ask again for this network" checkbox and select yes
    4. got to SSID advanced settings and verified "Auto connect" is on
    5. Turn off the camera
    6. Turn on camera - the wifi does not reconnect.
    7. Open wifi networks list
    8. Wifi camera does not reconnect. Select it manually to connect
    9. Observe the "SSID has no internet" notification again
  2. Trishala Anusha
    OnePlus Bug Hunter Staff Member Sep 12, 2021
    Trishala Anusha , Sep 12, 2021 :
    We understand your concern and relate to the issue you are facing and would need more details to get this rectified. Please have a look in your inbox, we've sent a direct message. Awaiting for your revert!
    Regards,
    Anusha
