[Submitted] The proximity sensors and ambient light sensors don't work properly
  1. soulphoenix Gingerbread Sep 2, 2018
    soulphoenix, Sep 2, 2018 :
    The proximity sensors don't work while on call. For example the notification panel automically comes down and the other toogles are turned on sometimes even flight mode is turned on.
    Also the ambient light sensor doesn't work i.e. it doesn't automatically adjusts the brightness according to the light unless the automatic brightness toggle is turned on and off.
    chester4400 likes this.
  2. chester4400 Froyo Jun 25, 2019
    chester4400, Jun 25, 2019 :
    i have the same problem on my op7 pro, especially with 3rd party apps like google duo where the proximity sensors doesn't work at all and with other apps or phone dialer sometimes it work sometimes it doesn't, it's really annoying i get many things open with my face while on call..
  3. soulphoenix Gingerbread Jun 26, 2019
