The speed i don't need
  1. 7569
    Cupcake Oct 10, 2018
    7569 , Oct 10, 2018 :
    It's been an year exactly 10 days ago, I've been using one plus 5 since September last year. Is it some auto destruct or what ? After just completing an year my battery drains like a rocket{this speed i don't need} it's not making even a mere 2 hour span. And I can now use this phone to heat water as it is water resistant. It's heating like hell. I don't know how to respond to this situation. I am just wondered why is it happening now exactly after a year. Is it with just this device or every device made by you behaves the same ? So, what should I do now ? Please concentrate on us too.
    X1517396854503 likes this.
  2. Nope.
    Gingerbread Oct 10, 2018
    Nope. , Oct 10, 2018 :
    post battery stats. nobody believes without proof. stop whining nobody else I know has had this issue
  3. xtar_ar
    Eclair Oct 10, 2018
  4. M1537801500896
    Eclair Oct 10, 2018
  5. 7569
  6. vivekgokulraj
    Honeycomb Oct 10, 2018
  7. 7569
    I've done everything i could and everything i know. They were useless.
  8. vivekgokulraj
    vivekgokulraj , Oct 10, 2018 :
    how did you cleared the cache of your phone.. elaborate
  9. 7569
    settings>storage>cached data.
  10. vivekgokulraj
    7569
    settings>storage>cached data.​
    shutdown your phone. after 2 minutes, press volume down button+ power button together. this will take you 2 a recovery mode. there decrypt your device by entering password or pattern. there u will find wipe data and cache. go into that and clear only cache
  11. 7569
    I'll try, thanks
  12. elanglois
    Lollipop Oct 10, 2018
    elanglois , Oct 10, 2018 :
    Nooooooo
  13. 7569
    it's been 15 mins and 5% drained even after normal use. All i did was what you told me to do so and nothing else. I just wiped the cache.
  14. elanglois
    Try putting a cat in a paper bag and swing it around your head.
    That will fix it right? Why do people always want to blast away the cache every time they have a problem. The most common reason for low battery excessive heat is some idiot wiping the cache! The second most common reason is an app.
    Unless you are willing to figure out what your phone is doing and why, then you might as well find a cat. It's just as likely to work as any of the other tricks people say to use.
    And incidently, the cache in storage settings is different from what is wiped in recovery. Totally different things for different purposes.
  15. 7569
    I can understand your sarcasm. What I need is a solution ? It'd be of great help if you use your wit in helping me sort out this situation . Thanks
  16. vivekgokulraj
    android system is using 43 percentage of your battery. after cache clearling. charge your phone once and observe your phone for 2 days
  17. 7569
    I don't understand why my android system is taking 56% of battery when no app is running in background?
  18. metallized
    Eclair Oct 10, 2018
    metallized , Oct 10, 2018 :
    If possible, reset your phone to factory settings. As Android usage is 56%, there might be virus in your phone.
    This will be the solution you'll be getting from Technical Support Team of Oneplus as well.
  19. metallized
    Eclair Oct 10, 2018
    You can try to turn off background activity of "Android System" and check.
    Settings-->Battery-->Android System
    For my phone, "Android System" usage is only 3%.
  20. Paschfire
    KitKat Oct 10, 2018
    Paschfire , Oct 10, 2018 :
    You have a huuuge Android system wakelock, install Better Battery Stats and see what rouge background service, or app, that is causing it.
