The version of your selected Package is lower than that of the current system. via OnePlus Nord
  1. dubeypawan1
    Cupcake Sep 18, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 18, 2021
    Best Answer
    Caomhin likes this.
  3. Dresa91
    Caomhin likes this.
  4. dubeypawan1
  5. Dresa91
    Dresa91 , Sep 18, 2021 :
    Where did you download it from?
  6. dubeypawan1
  7. dubeypawan1
  8. Dresa91
    But why do you want to install this? This version is older than your installed version. That’s why you are not able to flash it via System local upgrade method.
    Caomhin likes this.
  9. dubeypawan1
    dubeypawan1 , via OnePlus Nord , Sep 18, 2021 :
    Actually I have found some bug like when I connect bluetooth device with phone. I can see it in my bluetooth settings but can't find it while changing between devices in volume settings.
  10. Dresa91
    And you want to downgrade to an older version?
    A downgrade will wipe your data
  11. dubeypawan1
  12. dubeypawan1
    Dresa91 likes this.
  13. dubeypawan1
  14. Dresa91
    You can give it a try
  15. dubeypawan1
  16. Dresa91
    For the bug.
    If you are still facing the issue after the reset, you can downgrade
  17. dubeypawan1
  18. dubeypawan1
  19. Dresa91
    Caomhin likes this.
  20. SlackW_1993
    KitKat Sep 18, 2021
    SlackW_1993 , Sep 18, 2021 :
    On OnePlus devices the Downgrade or Upgrade proccess is very easy to understand : for OnePlus the policy (and not general Android policy) is only based on the date of the build and nothing else. So of course you cannot simply downgrade from OS 11.1.5.5 to OS 11.1.1.3.
    To downgrade properly you must simply use a SPECIAL downgrade package such as this provided in Open Beta thread number 1 for OnePlus Nord which is a downgrade to OS 10.x.x.
    When the downgrade is done any Official OnePlus release with a superior build is easy to achieve.
    As usual the downgrade delete the datas, apps and parameters so a backup is recommended first on an external device (HDD, SSD, computer ...). Warning : it's only USB 2.0 transfer protocol !
    Note : OxygenOS 11.1.1.3 is considered a very bad build and radical improvements have been made since OxygenOS 11.1.4.4 with major bugs now solved (notifications, battery drain and much more ...) and consolidated in OS 11.1.5.5. It's the reason why the version semantics has accordingly changed.
