4
there is some serious battery problem with the oxygen 4.1.3 and Android 7.1.1 update
  1. G_Piyush_DaGr8_HzsH Donut Apr 19, 2017
    G_Piyush_DaGr8_HzsH, Apr 19, 2017 :
    After upgrading today to oxygen os 4.1.3 and Android 7.1.1 nougat I'm facing problems regarding the battery of my one plus 3t. The battery is at 50% and not decreasing even after using for three hours. Also restarting has not affected it in any way. when I'm trying to charge it, it gives a warning saying phone too cool to recharge. please fix this issue as soon as possible I'm freaking out [e]1f628[/e][e]1f628[/e]
  2. vanyo Donut Apr 19, 2017
  3. HWAM Honeycomb Apr 19, 2017
    HWAM, Apr 19, 2017 :
    I know there is something wrong. I noticed a big difference too. Android System and Android OS keep awake problems. Terrible.
    TomHatter, Laamapalmu and Dinoxanxus like this.
  4. airiartev Jelly Bean Apr 19, 2017
    airiartev, Apr 19, 2017 :
    Whatsapp has some sensors battery issues. Thread created
    Do you have it installed? Could you check your whatsapp sensors in gsam battery?
  5. G_Michaela_Mayerl_KNto Cupcake Apr 19, 2017
  6. Sehrkrassertyp Cupcake Apr 19, 2017
  7. G_Piyush_DaGr8_HzsH Donut Apr 19, 2017
  8. G_Piyush_DaGr8_HzsH Donut Apr 19, 2017
    so you mean to say I discharge it fully and then switch it on after charge??
  9. G_Bhaskar_S_ohUs Froyo Apr 19, 2017
    G_Bhaskar_S_ohUs, Apr 19, 2017 :
    go to recovery mode and wipe the cache ,this should help
    to enter into recovery mode power off the phone.
    then press volume down and power button at the same time, then you will enter to recovery mode and clear the cache and reboot the phone
  10. Sehrkrassertyp Cupcake Apr 19, 2017
    Sehrkrassertyp, Apr 19, 2017 :
    Boot into recovery, wipe cache and Dalvik. Be careful not to wipe anything else!
  11. Sehrkrassertyp Cupcake Apr 19, 2017
    Yes, you may even have to do that a few times. Just use it until it turns off, fully charge and then use until power off again. That's a common thing to do with miscalibrated battery percentage displays, it may or may not work for you. Try the cache cleaning before, though, as it's a bit faster to check for results when doing that.
  12. HWAM Honeycomb Apr 20, 2017
    HWAM, Apr 20, 2017 :
    How can I find out which process is keeping my OnePlus 3T awake??? It's Android OS or Android System.
  13. G_MrNinjaOutside_YourDoo Cupcake Apr 21, 2017
  14. F_Chaitanya_Zaveri_Pify Froyo Apr 21, 2017
    F_Chaitanya_Zaveri_Pify, Apr 21, 2017 :
    I sometimes face this issue where the fingerprint reader doesn't read my prints.Especially after the update.It even doesn't give me a vibration feedback.Someone else facing it too? I don't if this is sure to the update or is it a hardware issue.Any help??
  15. Sai Teja Vaidya Cupcake Apr 21, 2017
    Sai Teja Vaidya, Apr 21, 2017 :
    Hi All,
    I have updated my one plus 3T to Android 7.1.1 running on 4.1.3 OxygenOS version. I am facing a weird problem, i am getting a message as "Check Network Connection" continuously even though my WIFI and Mobile Data is turned off.
    When WIFI and Mobile Data are turned off i was not getting any such message before Update from 7.0 (4.0.3) to 7.1.1 (4.1.3).
    Please let me know how to resolve this issue.
    Also let me know in case any of the One Plus 3T users are facing the same problem.
    Thanks in Advance.
  16. G_Avee_B_Xaxb Jelly Bean Apr 21, 2017
    G_Avee_B_Xaxb, Apr 21, 2017 :
    lucky for me then, i got updated to 4.1.3 but still manage to get around almost 6:30 hrs sot with 10% battery left. i have facebook, messenger, skype and whatsapo installed with autosync ON, autobackup enabled. standby drain though is around 13% for 7hrs sleep when connected to wifi and around 6% when connected to mobile data
  17. Ludovic_MAILLET Cupcake Apr 21, 2017
    Ludovic_MAILLET, Apr 21, 2017 :
    Il have the same problem since Fryday and the ota update to 4.1.3, while cache did not resolve the issue.
    before the update, in the same case, the estimated time will be at least 24h left.
  18. G_Ian_Smith_FuYg Donut Apr 21, 2017
  19. ShredMeister Honeycomb Apr 21, 2017
    ShredMeister, Apr 21, 2017 :
    "after upgrading today"... enough said.
    Is it really that difficult to understand that battery consumption is something that needs time to settle down? Two or three charge cycles is a bare minimum.
  20. HWAM Honeycomb Apr 21, 2017
    HWAM, Apr 21, 2017 :
    I know but the device is constantly awake!! I can't find the process which is doing this.
    Dinoxanxus likes this.
