there is something loose in My front camera
  1. Emppuone
    Cupcake Dec 1, 2019
    Emppuone , Dec 1, 2019 :
    when i shake My oneplus 7 pro i hear like a loose piece or something around the front camera is it supposed to be like that or is it Broken because The camera Still works fine
    MBBuffa likes this.
  2. Ytkuser
    Gingerbread Dec 3, 2019
    Ytkuser , via OnePlus 7 Pro T-Mobile , Dec 3, 2019 :
    if bought from OnePlus call support not supposed to do that should be nothing loose in there. if got from a local store or your cell plan call them, you may have to send back.
  3. darknagel
    Eclair Dec 14, 2019
    darknagel , via OnePlus 7 Pro , Dec 14, 2019 :
    thats normal. Thats the image stabilization of the back camera. try to Open the camera and Shake it. did you hear the diffrence.
    all ist good with your Phone
    MBBuffa likes this.
  4. MBBuffa
    Cupcake Nov 3, 2020
    MBBuffa , via OnePlus 8 Pro , Nov 3, 2020 :
    Thank you! Same thing was on my 8 Pro. I was so concerned:) Now I know that there is nothing wrong[e]1f60c[/e]
