Third Party Applications Not Installing After Changing From Android 11 Beta To Android 11 Stable via OnePlus 6
  1. Csk_paul
    Cupcake Sep 22, 2021
    Csk_paul , via OnePlus 6 , Sep 22, 2021 :
    I recently Rolled Back My OnePlus 6 from android 11 beta to android 10.. then I installed the stable android 11 version.. after that I unable to install any third party apps.. package installer failled to install the apps other than playstore apps
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 25, 2021
    Best Answer
    Csk_paul likes this.
  3. Shailender Sharma
    Nougat Sep 22, 2021
    Shailender Sharma , Sep 22, 2021 :
    Go to Settings - Apps and Notifications - Special app access - Scroll down to Install unknown apps - Allow from this source for example Chrome, enable the toggle here.
    Screenshot attached for reference.
    Artemus likes this.
  4. Csk_paul
    That's not the problem bro.. I already enabled it.. whenever I try to install 3rd party apk files, the package installer closes without installing..
  5. Shailender Sharma
    Nougat Sep 22, 2021
    Try to clear the cache in the recovery mode. It might help.
    Artemus and Csk_paul like this.
  6. Csk_paul
    I tried now bro.. but the same result.. I just updated the screenshot for the reference.. and thank you for the ideas
  7. Shailender Sharma
    Nougat Sep 25, 2021
  8. Csk_paul
    Cupcake Sep 25, 2021
  9. Dresa91
    Dresa91 , Sep 25, 2021 :
    You are welcome:)
    Let me know if a factory reset helped :)
  10. Csk_paul
    Cupcake Sep 27, 2021
    Dresa91 likes this.
  11. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 27, 2021
    Dresa91 , Sep 27, 2021 :
    Great :) You are welcome:)
