Thoughts on 6T camera
  1. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    F_Omair_Malik_SKTv, Nov 12, 2018 :
    here's hoping [e]1f44d[/e]
  2. LouCap Honeycomb Nov 12, 2018
    LouCap, Nov 12, 2018 :
    Not to mention the fact that the 6T has a PRO mode. If you're getting into photography, this will open up a whole new world for you.
    msudz923 and F_Omair_Malik_SKTv like this.
  3. pkair Honeycomb Nov 12, 2018
    pkair, Nov 12, 2018 :
    If camera is the only thing you care about then go elsewhere. OnePlus 6T camera is ok. All pictures/videos I have taken so far not even close to what OnePlus have posted/shown but overall I am happy with it. I had OP3T and I think it's camera is much better than 6T's. I bought 6T only for it's display.
    F_Omair_Malik_SKTv likes this.
  4. guisbro Honeycomb Nov 12, 2018
    guisbro, Nov 12, 2018 :
    I don't put a high value on the camera so it wasn't a priority for the phone. The stock camera is fine but not exceptional in normal lighting. I installed Google Camera which I use for low light.
  5. KidAKidB Froyo Nov 12, 2018
    KidAKidB, Nov 12, 2018 :
    I came into the 6T expecting the camera to be garbage compared to my previous Note 9 and Pixel 2 XL, but so far I'm happier with the 6T camera than the Note 9. The Pixels camera was a whole different level, but I am still enjoying the 6T.
  6. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    I do care about a good camera but it's not the bee all and end all. I also value battery life, connectivity, display, durability and display are all important. I was happy with my OP3 despite an average camera. I understand you can't get everything u want at this price point. sounds like the camera is not stellar but not a deal breaker either.
  7. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    I think this Google cam info may make me go for the 6T :)
    LouCap likes this.
  8. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    Good information thanks. As an overall experience do you prefer the 6T or the Pixel 2XL?
  9. KidAKidB Froyo Nov 12, 2018
  10. Kamaal Ansari Donut Nov 12, 2018
  11. MilianDue Donut Nov 12, 2018
    MilianDue, Nov 12, 2018 :
    F_Omair_Malik_SKTv
    Good information thanks. As an overall experience do you prefer the 6T or the Pixel 2XL?​
    With de GCam Mod, i prefer 6t! I owned the Pixel 2XL before.
  12. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    wow! GREAT!! [e]1f601[/e]
  13. pkair Honeycomb Nov 12, 2018
    Connectivity is fine I think. My OP5T was keep disconnecting from my Subaru Crosstrek bluetooth audio but OP6T doesn't. And i think OP6T does have weak antenna for mobile network even tho it supporting all the bands. I have a friend who sits next to me with iphone 7plus and getting signal at work while my OP6T doesn't (we are both on US TMobile) but I use wifi calling so it helps but still I believe antennas of OP6T are weak for mobile network. Wifi works great no issues so far. Display is amazing no complaints there at all however the brightness is a bit weak as well especially under the bright light. Battery life around 6-8 SOT under normal usage (navigation, internet, text, calls, some videos on youtube, netflix and etc. and music all day). Overall experience is what android should be. Fingerprint scanner is fine (not the fastest) but I have nothing to hide so my phone unlocked all the time anyway.
  14. Sameerspandit Eclair Nov 12, 2018
  15. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    I was staring at the Pixel 3 and 6T side by side and kept feeling the 6T was the more premium feeling device and I really like Oxygen OS.
    KidAKidB likes this.
  16. KidAKidB Froyo Nov 12, 2018
    Indeed! The OnePlus feels so premium and Oxygen OS has so many useful features.
  17. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    Great synopsis. Never knew about this weak antenna! makes sense as I ah serious drop out of signal when at home.
  18. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    #38
    Abin_123 likes this.
  19. F_Omair_Malik_SKTv Froyo Nov 12, 2018
    #39
    msudz923 likes this.
  20. KnightofScorpio US Brand Ambassador Nov 12, 2018
    KnightofScorpio, Nov 12, 2018 :
    The camera on the 6T is pretty good. What I will say is the beauty about Android is the freedom, the ability to modify, and customize to your liking. There's an APK for the Pixel 3 camera specifically made for the OnePlus 6T developed by a developer over at XDA. I've been using it for about a week and it's AMAZING. It completely takes the OnePlus 6T camera to the next level.
    The OnePlus 6T has the hardware, they just have to continue working hard at honing in the software for the best image processing results.
    Check out the results here
    #40
