Thoughts on 6T camera
  1. NMD2018 Honeycomb Nov 15, 2018
    NMD2018, Nov 15, 2018 :
    I purchased the 6T to replace my Pixel 2 XL because I want to be able to sell the phone with a decent price while the phone is still 1 year old.
    Personally, the 6T camera isn't good and a huge downgrade but that is what I expected. I plan to keep the phone anyways because I love the software and performance with a big screen.
    I still notice a bit of the paint effect just like the Oneplus 5 but it isn't so bad.
    #81
  2. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    #82
  3. leebrandonhope Cupcake Nov 16, 2018
    leebrandonhope, Nov 16, 2018 :
    But the Pixel and Samsung's are operating in a difference price bracket. Yes OnePlus could pay more for a better camera, but then the price goes up with it. I'd like to see OnePlus stay around the £500 mark.
    #83
    Sameerspandit and NMD2018 like this.
  4. D1542209490006 Cupcake Nov 16, 2018
    #84
  5. LouCap Honeycomb Nov 16, 2018
    LouCap, Nov 16, 2018 :
    Yeah, you're right... it's awful.
    #85
  6. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    #86
  7. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    G_Joshua_Cho_ZblJ, Nov 16, 2018 :
    #87
  8. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    #88
  9. LouCap Honeycomb Nov 16, 2018
    Actually, I was being facetious. I think the camera is pretty good, and I believe the images I posted show that!
    One reason your images look bad is that they're backlit. You're getting lens flare from the light behind the phone you're photographing, and it doesn't look like you have any light on the front of your subject. The camera can only do so much my friend.
    Here's two behind the scenes shots from a recent commercial shoot using the back camera with stock app.
    Here's one from the front camera with Portrait mode in stock app.
    #89
  10. D1542209490006 Cupcake Nov 16, 2018
    #90
  11. LouCap Honeycomb Nov 16, 2018
    I would send it back under warranty. sounds like an issue with your unit.
    #91
  12. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    Wow those are great photos. Thanks for the feedback. But when I took pictures of my daughter this morning. It wasnt much different. It was outside with sun but it was very dull. It wasn't vibrant like your pictures. I took better photos with 5t
    #92
  13. LouCap Honeycomb Nov 16, 2018
    Hmm...there might be an issue with your phone then. Just out of curiosity, there's no plastic wrap on the phone or covering the lens, right? I can't recall if it shipped with a protective plastic shield over the lenses.
    #93
  14. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    No. I tried to peel the lens, but nothing. I got mine from the tmobile store.
    #94
  15. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    Here is another example. You can clearly see one is more vibrant.
    #95
  16. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    #96
  17. LouCap Honeycomb Nov 16, 2018
    #97
  18. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    Oh OK. Darn, this is 2nd time exchanging my phone. First one, I had problem with the battery.
    Well thanks for your advice!
    #98
    LouCap likes this.
  19. LouCap Honeycomb Nov 16, 2018
    Go to the XDA Developer's website and search for the 6T in the forums. I found a link in there to download the APK. Basically, all you do is install it like any other app.
    #99
    G_Joshua_Cho_ZblJ likes this.
  20. G_Joshua_Cho_ZblJ Gingerbread Nov 16, 2018
    I tried that, but the app didn't work. It just closed itself.
