Thoughts on Oxygen 10.0.1 / Android 10.... via OnePlus 7 Pro
  1. trailrunner76
    Eclair Oct 21, 2019
    trailrunner76 , via OnePlus 7 Pro , Oct 21, 2019 :
    I've been on the Oxygen 10.0.1 / Android 10 for a week or soon the Oneplus 7 pro. So far I'm really digging the upgrade of Oneplus. I especially like Oneplus's take on the sidepanel to go "back". it's something I'm constantly needing to do and like that it's easy to get to and very responsive. oneplus does it better than the way Google android 10 does it, which requires more hand motion and feels a bit awkward.
    also I like the dark mode and how you can go into the developer section and override do that it's dark mode across all apps.
    keep up good work oneplus
    David Y. likes this.
  2. A1565258340002
    Cupcake Oct 21, 2019
    A1565258340002 , Oct 21, 2019 :
    Hi there!
    I have Oxygen 10.0.1.GM21BA / Android 10.
    Does anyone see glitches when scrolling in the settings only with dark tone?
    1) Go in settings > Customization > System customization > Tone
    2) Choose the Dark tone.
    3) Then come back in "Settings" and scroll down and up.
    I can see kinda blue-ish inner shadows on the icons - and sometimes on texts - when scrolling in the settings. This seems to happen only with the dark tone.
    Not sure if this is expected behavior but it definitely looks glitchy.
    Thanks
  3. kkisrich00
  4. Bichigo
    Bichigo , Oct 21, 2019 :
    - Been having random disconnects from LTE (I have Verizon)
    - Video from any app won't play unless I reboot (Facebook, Youtube, Instagram)
    - Had a random reboot out of nowhere an hour ago
    I'll probably update more as I encounter them
    I1571677575452 likes this.
  5. Eidvilas Zailskas , via OnePlus 7 Pro , Oct 21, 2019 :
    Yep, having the same problem with videos on FB, Insta
  6. trailrunner76
    Eclair Oct 21, 2019
    I found camera quality photos to be unchanged. no better, no worse. I think one camera mode added "telephoto". that's only new added feature I observed
  7. trailrunner76
    Eclair Oct 21, 2019
    1. haven't seen those random LTE disconnect myself. I'm also in Verizon(in Bay area). I use carrier connection 100% of the time instead of wifi, even at home.(unlimited data)
    2. I only have Facebook, no Instagram. video that was available, played ok. you may have to see if there is a way to submit error report to oneplus
  8. I1571677575452
    I1571677575452 , Oct 21, 2019 :
    Multiple issues with IG stories.
