Three Mobile 4G LTE
  1. OW3N111
    Jelly Bean May 14, 2015
  2. dustbunnyck
    dustbunnyck , May 14, 2015 :
    America is also much larger land mass compared to UK. Gotta pay for the whole country not just local
  3. CandyMan98
    Eclair May 14, 2015
    CandyMan98 , May 14, 2015 :
    Wee ladie! Wat part r u from?
    Still trying to calm down after damm Tories took over!
  4. TekRantGaming
    Ice Cream Sandwich May 14, 2015
    TekRantGaming , May 14, 2015 :
    Easy Ayrshire.... Am still ragin was the tories.... We cany get a break
  5. koltiwa
    koltiwa , May 14, 2015 :
    Three £15 payg, unlimited data, 300 mins, 3000 txt. Have 4G in Gtr Manchester which peaks around 10meg - not the fastest but it's a strong signal and good enough to stream HD video. Firmware is YNG1TAS17L.
  6. kinky-chinky
    Cupcake May 14, 2015
    Jupeeeeee likes this.
  7. fenners17
    Cupcake Jan 10, 2016
    fenners17 , Jan 10, 2016 :
    I have good 4G but I experience some dodgy call reception. Probably about 25% of the time I sound as though I'm underwater to the other caller. I can hear them fine, though.
  8. greendragon
    Ice Cream Sandwich Jan 10, 2016
    greendragon , Jan 10, 2016 :
    With 3 i get 200 min, 5000 txts and all I can eat data for £12.50. 4g is awesome in Llanelli...
    bmark240 and merewoodbebox like this.
  9. merewoodbebox
    Jelly Bean Jan 10, 2016
    merewoodbebox , Jan 10, 2016 :
    When you buy a phone in future, the 800mhz band is useless unless you buy the phone from three. This is because the 800 mhz is for VoLTE only, which requires software and an approved device from three. I'm using the OnePlus 2 and I'm in a 800mhz area but still only using the 1800 band
  10. haruhisuzimiya
    Honeycomb Jan 10, 2016
    haruhisuzimiya , Jan 10, 2016 :
    On CM13, is anyone having issues with LTE dropping out occasionally, even when the signal on the status bar says otherwise, and phone calls not working (no sound)?
    I've tried the latest CM Modem (00011) and the latest H2OS Modems (00004 & 00013). All have the same problems.
    However using OxygenOS's modem (00241) makes calls and LTE work properly, but causes random reboots. And trying to flash the 44S modem just makes my SIM card not get recognised.
    And yes, of course I am on the Three UK network.
  11. zorg93
    Honeycomb Jan 11, 2016
    zorg93 , Jan 11, 2016 :
    While I'm not using CM13, I'm using cos12.1, with the 00241 modem I'm having no issues with signal or stability issues (random reboots)
  12. haruhisuzimiya
    haruhisuzimiya , Jan 11, 2016 :
    Problem is I don't want to go back to using CM12.1 or COS12.1. I like having the latest Android OS, and CM13 is very fast. Plus I'd have to do a factory reset.
  13. haruhisuzimiya
  14. SexyHyde
    Ice Cream Sandwich Jan 11, 2016
    SexyHyde , Jan 11, 2016 :
    If you like having the latest cutting edge unofficial software then you need to be prepared for bugs. Either roll back to the last configuration that worked or go to stock.
  15. haruhisuzimiya
    Honeycomb Jan 12, 2016
    haruhisuzimiya , Jan 12, 2016 :
    Actually, I've managed to fix my own problem. Read it here to see how I did it.
