6
Tingly feel /vibration while charging
  1. graemefarrer Cupcake Jan 19, 2017
    graemefarrer, Jan 19, 2017 :
    It's quite normal with metal bodied laptops and mobiles.
    The answer lies in improper grounding in the socket that you connect your mobile charger to.
    Observe that you wont find this strange buzz when your mobile operates just on your battery i.e your charger is disconnected.
    This improper grounding basically means that electricity is being conducted through your body to the floor.
    Also try and keep your legs in the air or on wood i.e don’t touch the ground. You won’t find the buzz anymore. Hope this solves it :)
    #41
  2. Deactivated User Jan 29, 2017
    #42
  3. Saurabh3321 Cupcake Jan 29, 2017
    Saurabh3321, Jan 29, 2017 :
    This is normal. No need to replace.
    And to the guy who suggested it is due to improper grounding, notice that the charger doesn't have a ground pin. So this is bound to happen.
    #43
  4. TheAmatuerBanana Gingerbread Jan 29, 2017
    TheAmatuerBanana, Jan 29, 2017 :
    it is the force being channeling onto you via dash charge. you are "One+" with the force and the force is with you.
    #44
  5. Deactivated User Jan 29, 2017
    #45
  6. Saurabh3321 Cupcake Jan 29, 2017
    I can't really answer why they're suggesting replacement, but you will find the same thing on the replaced unit as well. I own a lot of devices with metal bodies: tablets, laptops and phones. Most devices have this. That tingly sensation is because some current leaks in the body of the device (which is essentially a ground for the device) and that current passes through your body to the floor. The lower the resistance between you and floor, the stronger the current you'll feel. Try it barefoot and you'll find it getting stronger.
    It is normal. It is well within limits so you won't feel a shock.
    #46
  7. gandhar14 Cupcake Jan 29, 2017
    #47
  8. onkarr Gingerbread Jan 29, 2017
    onkarr, Jan 29, 2017 :
    yes i can feel it try to run your finger on side metal body.its like strong static force.
    #48
  9. Deactivated User Jan 29, 2017
    #49
  10. Saurabh3321 Cupcake Jan 30, 2017
    Saurabh3321, Jan 30, 2017 :
    The earpiece grille is made of metal. So thats same as the body.
    #50
  11. F_Jun_Pia_IZHz Cupcake Jan 30, 2017
    #51
  12. Deactivated User Jan 30, 2017
    #52
    F_Jun_Pia_IZHz likes this.
  13. bunny99 Eclair Jan 30, 2017
    #53
  14. F_Jun_Pia_IZHz Cupcake Jan 31, 2017
    F_Jun_Pia_IZHz, Jan 31, 2017 :
    Really? It has to be returned because of this? Please tell me who to contact.. Thanks.
    #54
  15. Deactivated User Jan 31, 2017
    #55
  16. Abhi Dahiya Ice Cream Sandwich Sep 22, 2017
    Abhi Dahiya, Sep 22, 2017 :
    WOW! Can't believe some people here ended up replacing their phone because of this. This is not a hardware fault, neither a software one. And neither does OnePlus has anything to do with it.
    It is due to power sockets in one's house not being properly grounded or due to not having 3rd pin in the charger.
    Just do a google search and you will find it happens to any device that is made up of metal. iPads, macs, Samsung's, htcs, OnePlus, sony or any other manufacturer.
    And because of some users' ingenious attitude, company would have to take back perfectly okay phones causing them losses.
    #56
    remedy likes this.
  17. nqddnwhb Donut Sep 23, 2017
    nqddnwhb, Sep 23, 2017 :
    Same to me. I use Rhinoshield Crashguard Bumper on my OP3 when I charging, I can feel the stroking at the back of my phone.
    #57
