6
[TL;DR REVIEW] Samsung 9,000 mAh Universal Battery Pack
  1. vantt1
    Jelly Bean Nov 22, 2014
    vantt1 , Nov 22, 2014 :
    I'm feeling lazy this time around :p
    Features:
    • It's EXACTLY 9,000!!! (mAh)
    • Comes with two ~6" charging cables; Samsung 30-pin and micro USB
    • Charges at 1.8 A! That's the same as using a 2 A wall charger, because the phone regulates it to 1700 mA I think (depending on kernel configuration (I think))
    • Four LED power indicator, shows capacity upon switching the battery pack on using the power switch
    • Fully charges the OnePlus One in about 2.5 - 3 hours, 2.5 - 3 times on one charge of the battery pack (what a coincidence!)
    Saves on excess cable on the go, I suppose
    1 LED = 25%, last LED will flash red when down to 5%, turns red when the battery is being charged
    1 x micro USB in, 1 x standard USB out
    Notable specs - INPUT: 5.0V DC 1.8A, OUTPUT: 5.0V DC 1.8A, 3.8V Li-ion BATTERY 33.6 Wh
    Pros:
    • Charges quickly
    • Good value ($55 from Costco)
    • High capacity
    Cons:
    • LED capacity indicators can't be manually invoked without switching the battery pack off and on again
    • Supplied 30-pin cable could've easily been made compatible with Apple's 30-pin by adding extra notches on the other side (or bundle one of those 4-in-1 cables)
    Middle 30-pin connector is reversible
    Rating: 8/10
  2. heavik
    Gingerbread Nov 22, 2014
    gusuraman likes this.
  3. Iweed1
    Eclair Nov 22, 2014
  4. peteryu
    KitKat Nov 22, 2014
  5. yotam_dobrin
    Ceasedd likes this.
  6. mwebsterpgh
    KitKat Nov 22, 2014
  7. vantt1
    That's, like, closer to $50 CAD :confused:
    Did you get it discounted?
    I wouldn't say it's that bad value. I personally trust Samsung more than Limefuel when it comes to reliability and quoted figures, and the Samsung battery pack was $55 from a brick-and-mortar store. Costco also has a "no questions asked" return policy, which is nice to have.
    It's good to have just in case you're close to running out and can't stay in one place to charge from a wall. It saved me from having a flat One at least two times (and many times with other phones before that) :)
  8. IWantOneNow
    KitKat Nov 22, 2014
  9. gusuraman
    Community Veteran Nov 22, 2014
  10. kestalkayden
    Froyo Nov 22, 2014
    vantt1 likes this.
  11. gusuraman
    gusuraman , Nov 22, 2014 :
    Braking news:
    "soon or late the OPO battery will discharg! "
  12. a_agarwal
    Ice Cream Sandwich Nov 22, 2014
    a_agarwal , Nov 22, 2014 :
    You would if you are travelling and out on the roads most of the time.
    vantt1 and gusuraman like this.
  13. a_agarwal
  14. Ericthedreamer
    Froyo Nov 22, 2014
  15. trx492
    Honeycomb Nov 22, 2014
    trx492 , Nov 22, 2014 :
    Prefer my Xiaomi 10400mAh. Less than half the price, bigger capacity, metal design, charges at 2.1a (same as wall charger)
    vantt1 likes this.
  16. Milad
    Lollipop Nov 22, 2014
    Milad , Nov 22, 2014 :
    I have been thinking about getting the Xiaomi powerbank, but this also looks interesting.
  17. trx492
    Interesting enough to outweigh all the cons vs the Xiaomi? Get the xiaomi, it's MUCH better value
  18. fino89
    Cupcake Nov 25, 2014
  19. jthe111
    Jelly Bean Nov 25, 2014
    jthe111 , Nov 25, 2014 :
    Always good to have a plan b when there is neigh a outlet in sight and your OPO is just shy of 5%
  20. dwong
    Ice Cream Sandwich Nov 25, 2014
    dwong , Nov 25, 2014 :
    how much is this? and how does it compares to the Mi Powerbank?
