Too many bugs for a brand new phone
  1. axeman3
    Donut Nov 18, 2015
    axeman3 , Nov 18, 2015 :
    1. Sd cards
    2. Over heating
    3. Battery draining
    4. No flash for photos, only showing for videos
    5 Radio, not all frequencies clear, can't port to bluetooth speakers, app crashes
    6. No release button for otg
    Urge op team to share timeline for expedited ota release, this is too bad for brand reputation/image. Very disappointed!
  2. Qazi.Rza
    Ice Cream Sandwich Nov 18, 2015
    Qazi.Rza , Nov 18, 2015 :
    Did you update the OS to the latest version??
    billq likes this.
  3. axeman3
    Donut Nov 18, 2015
    Yep, unfortunately I did. Would it help for the time being to reset or just wait for the ota update?
  4. axeman3
    Donut Nov 18, 2015
  5. Qazi.Rza
    Did you updated to 2.1.2?? if not then try to clear the cache from the recovery..& clear the system update cache also from the apps. Search for the OTA folder from the file explorer & clear it.
    After the ota update clear the cache again from the recovery.
  6. TlathamXmahtalT
    KitKat Nov 18, 2015
    TlathamXmahtalT , Nov 18, 2015 :
    Uhh, no; usually the newer the phone is, the more bugs it would usually have until they're ironed out by updates. Your logic is the opposite of what it should be.
    Spliffman likes this.
  7. axeman3
    Donut Nov 18, 2015
    I have updated to 2.1.2, so I guess this won't help?!
  8. axeman3
    Donut Nov 18, 2015
    This is not my first phone. I've used Nokia, HTC, BlackBerry, iphone, Moto, Xiaomi before Opx. I don't understand this fanaticism. If it doesn't work it doesn't work, but besides just admitting the flaws, one needs to act fast to regain consumer trust, that's all!
    gin0v4 likes this.
  9. billq
    Jelly Bean Nov 18, 2015
    billq , Nov 18, 2015 :
    Thats an unusually long list . if my opx had been like that I'd simply send it back . I've got the known micro SD card problem 2 not a hint of heating tho a warming is noticed on long use but slight .3 my batt lasts a very long day ,so I can't ask for more 4 I did have a flash problem on the op2 then this its in settings on your camera maybe mine was do a search. 5 radio is good but dependant on transmitter signal strength not opx. 6 yes otg need to be able to deactivate safetly to prevent possible corruption . hope this helps.
  10. Qazi.Rza
    Did you cleared the cache as I suggested?? in the similar order..
    billq likes this.
  11. axeman3
    Donut Nov 18, 2015
    how do I go to recovery?
  12. axeman3
    Donut Nov 18, 2015
    I guess will wait till next update before making up my mind about this phone
    billq likes this.
  13. billq
    Go to settings..... Storage..... Clear cach try that
  14. Venu_Appa
    Gingerbread Nov 18, 2015
    Venu_Appa , Nov 18, 2015 :
    The only problem i have encoutered is the SD card issue. An update should be coming within a week.
    I am not a heavy user BTW, I have not used the radio. My flash works as normal.
    I agree though that this OS is half baked
    billq and axeman3 like this.
  15. cboursinos
    Honeycomb Nov 18, 2015
  16. axeman3
    Donut Nov 18, 2015
    That I've been doing on a regular basis
  17. axeman3
    Donut Nov 18, 2015
    That's music to my ears, update in a week!!
  18. Thwomp
    Eclair Nov 18, 2015
    Thwomp , Nov 18, 2015 :
    Anyone have a Oneplus X invite to spare for a fellow Canadian? I'm trying to get one before Christmas :(
  19. Qazi.Rza
    2 ways.
    1. go to settings=about phone=build number=tap 7 times (this activates the developers option). Go back to settings= Developers option=tick the option of advanced reboot (by doing so you will get the recovery option in restart menu)
    2. switch off your phone then press the volume down button + Power button (simultaneously) and release the volume down button once you feel the vibration.
    Recovery= just wipe the CACHE ONLY. REBOOT. DONE.
  20. axeman3
    Donut Nov 18, 2015
    Okay I'll do that but which problem/s is this going to solve?
