[TOOL] 6T MsmDownloadTool v4.0.59 (OOS v9.0.13)
  1. ReamMao
    Cupcake Dec 26, 2019
    ReamMao , Dec 26, 2019 :
    This tool can be used to revive a bricked OP6T and remove the 'Device is corrupt' error message on boot.
    Contains the latest MsmDownloadTool v4.0.59 and OOS v9.0.13 which is compatible with International and McLaren editions.
    OOS v9.0.11 can also be used to convert a T-Mobile model into a fully fledged International model, more info here.
    https://forum.xda-developers.com/oneplus-6t/how-to/t-mobile-6t-to-international-t3888307
    Make sure that your phone is switched off.
    Open device manager on your Windows PC.
    Press and hold the Volume Up & Volume Down buttons then connect to your PC using your data cable.
    Once the device is connected to your Windows PC, check if the phone is being recognized (Other > QUSB_BULK or Ports > Qualcomm).
    If showing as Other > QUSB_BULK either wait for Windows to install the Qualcomm driver or download one of the drivers below and install.
    Run MsmDownloadTool V4.0 and click Start.
    NOTE: This will completely wipe your device and relock your bootloader.
    Downloads:
    https://androidfilehost.com/?fid=1395089523397966003
    6T MsmDownloadTool v4.0.58 (OOS v9.0.12)
    https://androidfilehost.com/?fid=1395089523397925035
    6T MsmDownloadTool v4.0.58 (OOS v9.0.11)
    https://androidfilehost.com/?fid=11410963190603895067
    6T MsmDownloadTool v4.0.58 (OOS v9.0.6)
    https://androidfilehost.com/?fid=11410963190603884688
    6T MsmDownloadTool v4.0.58 (OOS v9.0.5)
    https://androidfilehost.com/?fid=11410963190603846961
    Driver
    https://androidfilehost.com/?fid=11410963190603879743
    Alternative driver
    https://androidfilehost.com/?fid=817550096634746189
    https://forum.xda-developers.com/oneplus-6t/how-to/tool-6t-msmdownloadtool-v4-0-oos-9-0-5-t3867448
  2. H1578355945379
    Cupcake Jan 7, 2020
    H1578355945379 , Jan 7, 2020 :
    I Love you. I bricked my phone. Thought my phone is lost. But than came you. The first thing helped.
  3. Muhammad_Kashif_bahl
    Honeycomb Mar 4, 2020
  4. #4
  5. T1586712411318
    Cupcake Apr 12, 2020
  6. F1594194575391
    Cupcake Jul 8, 2020
    F1594194575391 , Jul 8, 2020 :
    i am getting Error in MSM tool ( Param Preload ) device not match the image plz help me :( i am stuck at bootloader and device state is locked plz help me
  7. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 8, 2020
    Caomhin , via OnePlus 6T , Jul 8, 2020 :
    F1594194575391
    i am getting Error in MSM tool ( Param Preload ) device not match the image plz help me i am stuck at bootloader and device state is locked plz help me​
    Please read the post before requesting help. This is for 6 series phones, as it clearly state throughout the original poster thread and links.
    ironass likes this.
  8. ironass
    Lollipop Jul 8, 2020
    ironass , Jul 8, 2020 :
    Alternatively, @F1594194575391 has a OnePlus 7 series phone and is trying to use the wrong MSMDownloadTool for the OnePlus 6T. See original post in the OnePlus 7 series section of the forum, here... https://forums.oneplus.com/threads/...stuck-in-param-preload.1107124/#post-21803313
  9. Caomhin
    This is what happens when a user posts in the wrong section and don't read the details before posting. Muppets. All the posts above his are for 6 Series phones. Plenty of mention in the OP.
    Walking unread huh 🙄🙄🤪🤪
    ironass and Bintang12 like this.
  10. Caomhin
    Most times you will get away with it, an odd time it could cause software damage to the partition system.
    I should have read his other postings elsewhere, but at the same time, the poster should be looking where they are posting. And especially not be downloading files from a 6 series thread for 7 series phones.
    Bintang12 and ironass like this.
  11. Mip2
    Donut May 7, 2021
    Mip2 , via OnePlus 6T , May 7, 2021 :
    [Solved]
    I used this tool to retrive my op 6t. But Now i can not opdate the phone. I downloaded the file from oneplus.com til internal Storage, and try too opdate. It says opdate fail opdatelog dosent exist. Please help.
  12. Caomhin
    OnePlus 9 Series Expert Community Expert May 7, 2021
    Caomhin , via OnePlus 9 Pro , May 7, 2021 :
    What version of OOS is currently on the phone?
    Mip2 likes this.
  13. Mip2
    Donut May 7, 2021
  14. Caomhin
    If you are OnePlus 6T you need to download and install OOS 9.0.17 as this contains files to allow you to update to Android 10.
    Download 9.0.17 for OnePlus 6T from link below.
    https://oneplusupdates.com/device/oneplus-6t
    After the .zip file is downloaded to your phone, move the file from the folder you downloaded to, to your Main Storage.
    Then go to 'Settings' - 'system update', click the 'settings' icon on the top right corner, choose 'Local upgrade', find the .zip file and click on 'Install' to confirm.The update takes about a minute (depending upon the file size), once done reboot your device to boot into the latest Oxygen OS.
    ⚠️Make sure you download the correct file for the model of phone you have. ⚠️
    Then choose your model of phone in the list in the link below and download and install the Android 10.3.8 file, follow the instructions given on the OnePlus Software Support page, link below.
    https://www.oneplus.com/support/softwareupgrade
    ironass, Mip2 and Bobbie63 like this.
  15. Mip2
    Donut May 7, 2021
    Bobbie63 and Caoimhín like this.
  16. Caomhin
    Bobbie63 and Mip2 like this.
  17. VickLord
    Cupcake May 12, 2021
  18. Caomhin
    OnePlus 9 Series Expert Community Expert May 12, 2021
    Caomhin , via OnePlus 9 Pro , May 12, 2021 :
    No, this is for Global versions only.
  19. VickLord
  20. Caomhin
    Not sure what you mean exactly by Buy another.
    This is a tool to unbrick or restore a non functioning OnePlus 6 series phone that suffers from a software fault.
