51
[Tool] JLouder v1.0 RC2 - Makes your phone call louder
  1. akramharbi
    Cupcake Aug 30, 2014
    Mrfantastic likes this.
  2. zaryab
    Ice Cream Sandwich Aug 31, 2014
    zaryab , Aug 31, 2014 :
    It says "java exception has occured" and doesnt open
    Edit: fixed, if its giving you this message then DONT GO TO DOWNLOAD THE LATEST JAVA BECAUSE THAT WILL DOWNLOAD 7
    go to google and download java 8, Please add this to your main thread so everyone can know!!!
  3. dkotagi
    Gingerbread Sep 20, 2014
    dkotagi , Sep 20, 2014 :
    I am trying to use this on my Samsung note 2 running cm 11. says unauthorized in status. means not built for this phone? I can try manual change
  4. TheOriginalMèêk
    Gingerbread Sep 21, 2014
    TheOriginalMèêk , Sep 21, 2014 :
    Oh.. Thank you very much. This seems to have fixed the low volume issue on 25R. I reeeallly appreciate that you took the time to develop this little tool. I don't want to update yet till a fairly stable OTA with good battery life is released.
    This little fix has allowed me to enjoy this phone as is for the time being.
    Thanks again
  5. shinraz
    shinraz , Sep 21, 2014 :
    Can anyone else update their One to 3O0 after doing this volume tweak? Files has been overwritten and device has an error when trying to perform a system update.
  6. davecgc
    Honeycomb Sep 21, 2014
    davecgc , Sep 21, 2014 :
    This modifies a system file (mixer-paths.xml). OTA updates notices that system files are not what it expects and stops. Unfortunately you need the original mixer-path file. should be a backup copy in root/system/etc.
  7. shinraz
    I'll check that out, thanks.
  8. gmack523
    Froyo Sep 27, 2014
    gmack523 , Sep 27, 2014 :
    Thank you for this! This is awesome! Keep up the great work!
    Now if you can just create something to make the signal strength stronger :)
  9. shinraz
    Gingerbread Oct 3, 2014
    shinraz , Oct 3, 2014 :
    There wasn't a root or system folder. [​IMG]
    Any idea where it could be?
  10. PIMPON60
    Honeycomb Oct 3, 2014
    PIMPON60 , Oct 3, 2014 :
    Pour accéder Il faut le voir sur l'explorer du téléphone ou avec une appli comme My rom explorer ou Mobilgo... sur PC
  11. markhodak
    Eclair Oct 6, 2014
    markhodak , Oct 6, 2014 :
    Not sure if you are still watching this thread but Thank You. I did not use your program, but the fact you explained how/where to find it was a godsend. I used root explorer and now I can hear my phone. Good luck and I hope in time I can code like this as well.
  12. shinraz
    Gingerbread Oct 7, 2014
  13. shinraz
    Gingerbread Oct 9, 2014
    shinraz , Oct 9, 2014 :
    Whoever did this volume fix, are you able to update your OPO to Android 4.4.4 & 38R?
    Gives me an error tmp/sideload/package.zip
    I tried to replace the mixer_paths.xml file but it wouldn't let me unless I am rooted.
  14. jokicha
    Jelly Bean Oct 9, 2014
    Jamesst20 likes this.
  15. steve8x8
    Donut Oct 11, 2014
    steve8x8 , Oct 11, 2014 :
    Indeed the 38R OTA update wants to change the file, as this diff snippet shows:
    Code:
    575c659
    <         <ctl name="RX1 Digital Volume" value="84" />
    >         <ctl name="RX1 Digital Volume" value="90" />
    628d711
    <         <ctl name="SLIM_0_RX Format" value="S24_LE" />
    633,634c716,717
    <         <ctl name="RX3 Digital Volume" value="84" />
    <         <ctl name="RX4 Digital Volume" value="84" />
    >         <ctl name="RX3 Digital Volume" value="92" />
    >         <ctl name="RX4 Digital Volume" value="92" />
    641d723
    Perhaps a reversal tool by the author of the original tool would help...
  16. gdream69
    Donut Oct 31, 2014
    gdream69 , Oct 31, 2014 :
    Hello everyone.
    For me it worked.
    I noticed that the problem of low microphone disappears if during normal phone conversation I put my finger on the microphone located on the right rear of the camera.
    The sound quality immediately improves and becomes excellent.
    I think it might be interesting for developers to program switching off the microphone back during normal phone call.
    What do you think about that?
  17. macula
    Cupcake Jan 8, 2015
  18. peteryu
    KitKat Jan 8, 2015
    peteryu , Jan 8, 2015 :
    No. Refer to this mod from XDA instead. (*note: root required)
  19. Jamesst20
    Jelly Bean Jan 14, 2015
    Jamesst20 , Jan 14, 2015 :
    Yes it still works. Only the reverter hasn't been updated
  20. peteryu
    KitKat Jan 14, 2015
    peteryu , Jan 14, 2015 :
    Oh, it works on 44S? Is root required?
    I did it with a flashable zip on xda lol
