303
[Tool] JOxygenOS Installer - Flawlessly clean install OxygenOS & COS12
  1. Jamesst20
    Jelly Bean Apr 8, 2015
    Jamesst20 , Apr 8, 2015 :
    Can you please double check your drivers ? First sideload which is the OxygenOS zip should take from 5-10 minutes. Second sideload should take about 5 seconds as it only locks the bootloader and afterwards it should reboot.
  2. Jamesst20
    Does my tool boots up TWRP 2.8.6.0 ? It should because it doesn't actually replace your recovery, it only boot the images without writting it. Your method should definitively replace the CM Recovery.
    And for your drivers. Nope your package doesn't fit the drivers requirement. Please see my first post on how to install them
  3. Jared Hoober
    Cupcake Apr 8, 2015
  4. Jamesst20
    Yes. But you will need to run the tool twice for Gapps as it is not meant for that in first place :p
  5. Jared Hoober
    Cupcake Apr 8, 2015
  6. Nick Hallacher
    Cupcake Apr 8, 2015
  7. Jared Hoober
    Cupcake Apr 8, 2015
  8. aravindma
    Cupcake Apr 8, 2015
    aravindma , Apr 8, 2015 :
    iam useing kitkat 4.4.4 version how can i update to oxygen os, plz any one give me the solution
  9. frankiecortina
    Ice Cream Sandwich Apr 8, 2015
    frankiecortina , Apr 8, 2015 :
    Sounds great and all for those users but does this install twrp for them ? Need to be sure they have a way to fix things in case ( unlocked bootloader , root, custom recovery etc.)
  10. frankiecortina
    I could teach you :)you got hangouts ?
    Jamesst20 likes this.
  11. Nick Hallacher
    Cupcake Apr 8, 2015
    Nick Hallacher , Apr 8, 2015 :
    Now in TWRP when sideloading it gives me
    E:Unable to mount '/data'
    Then proceeds to "installing 'sideload/package.zip'
    E: unknown command [wipe_data]
    format /system
    extract the package
    It appears to be working, but the errors are worrisome.
    EDIT: Alright it ran through the process, and sideload said it was complete. Your program told me to put it in sideload again and it went through its thing. Said "Oxygen install complete, please reboot' rebooted and now it's stuck in the OxygenOS boot animation. That's progress...at least it's not the Cyanogen one now.
    Actually getting in here when I can look at it. It's unable to mount anything.
    Unable to mount cache, unable to mount storage, ect. Error after error.
  12. sergioreja
    Honeycomb Apr 8, 2015
    sergioreja , Apr 8, 2015 :
    jamesst20, will you do something similar once CM12 comes? I mean, for the ones that have installed Oxygen and want to give CM12 a try. It'd be great!
  13. Joe1852
    Gingerbread Apr 8, 2015
    Joe1852 , Apr 8, 2015 :
    Does anyone know if I can simply drag the cm 12 nightlies instead of oxygen os?
  14. think
    think , Apr 8, 2015 :
    typo. sorry
  15. johnnymartz3
  16. johnnymartz3
    johnnymartz3 , Apr 8, 2015 :
    Im not really new to flashing new os with fastboot and recovery, but I'm not really confident in my abilities lol
  17. sam_muniz83
    Froyo Apr 8, 2015
    sam_muniz83 , Apr 8, 2015 :
    When installing PdaNet driver in Fastboot Mode, the PdaNet setup tool has been in "Updating PdaNet on your phone for over 15 minutes. Is this how long this takes? Has this happened to anybody else?
  18. Nick Hallacher
    Cupcake Apr 8, 2015
  19. Nicola.sandrini
  20. NousChristou
    Cupcake Apr 8, 2015
    NousChristou , Apr 8, 2015 :
    This Oxygen OS seems to be cutting edge. How can I beg someone for an invite? Please! I am so desperate! I have no phone! I want to use Oxygen OS!
