303
[Tool] JOxygenOS Installer - Flawlessly clean install OxygenOS & COS12
  1. Me1256
    KitKat Jul 17, 2015
    Me1256 , Jul 17, 2015 :
    No problem. Oh, and I meant process, not processor.
    Cosis likes this.
  2. dinku
    Froyo Jul 17, 2015
    dinku , Jul 17, 2015 :
    Hi
    HI Jamesst20
    Just want to tell you thank you very much for this brilliant tool.
    Its idiot proof.
    Used it on my Mac (Yosemite) to install Oxygen OS.
    Used the phone for a few weeks did not like it, so went back to CM 12.
    And this tool helped me install that too.....
    Absolutely delighted. Thank you very much.
  3. Jamesst20
    Jelly Bean Jul 23, 2015
    Jamesst20 , Jul 23, 2015 :
    Glad I helped you :)
  4. oonlo
    Eclair Jul 26, 2015
    oonlo , Jul 26, 2015 :
    Hi @Jamesst20 I'm just using this now to flash oxygen onto my COS12 OPO. is there any way to trick the phone into leaving TWRP on there or is there any way i can use this in order to load supersu and root the phone? or is there option for rooting in oxygen?
  5. Busjen
    Ice Cream Sandwich Jul 27, 2015
    Busjen , Jul 27, 2015 :
    My friend have i samsung note 3, and he have problem with flashing his phone, can i use this program or its only works with oneplus one.
  6. Jamesst20
    Jelly Bean Jul 27, 2015
    Jamesst20 , Jul 27, 2015 :
    Hi,
    You could close the tool after the first sideload and this way your phone would stay in twrp mode. The second sideload is mean't to relock the bootloader and reset tamperbit.
    Sadly it would probably not work since Samsung is not really using fastboot as far as I know and require a software such as Odin to reflash it
  7. fabim06
    Gingerbread Jul 27, 2015
    fabim06 , Jul 27, 2015 :
    Could u make like a video tutorial?
  8. Jamesst20
    Hi,
    I sadly cannot as I will be working for the whole week and i have lent my opo to a friend
  9. fabim06
    Its just that I never done so im kind of afraid of mess up thx although for the tut seems easy I'll try it
  10. Jamesst20
    Hi,
    There is no way you can break your phone with this tool. The worst that can happen is a bootloop where you would need to reboot the phone in fastboot and rerun the tool :)
    If you're using Windows (hopefully not) please don't forget to install the drivers.
    If you are using Mac, you're 95% confident everything goes perfectly well from 1st attempt because of the way drivers are handled
  11. fabim06
    Yes using windows lol by the way what are your thoughts on oxygenOS?
  12. Jamesst20
    I personally use CM12S but both runs very good. The only down side of oxygen is that some features are missing
  13. siva-kumar
    siva-kumar , Jul 27, 2015 :
    Wish the tool also helps to take backup and restore after flashing a new OS. Haven't tried this, as I am afraid of the effort to reinstall all the apps and configure them again.
  14. iMrMatthias
  15. solBLACK
    Eclair Jul 28, 2015
    solBLACK , Jul 28, 2015 :
    Installed CM12S after using OxygenOS for a while. Used this tool again with the updated CM12S bootable .zip file. Easy as pie. Question is how out of date is this CM12S? Also It says to update it, but I goes into a bootloader or something and doesn't let me apply the update.
  16. ashuashi
    Cupcake Jul 28, 2015
    ashuashi , Jul 28, 2015 :
    Hi, I used CM12s zip file to install it over oxygen OS but it ends up in oxygen only. I have done it twice but not able to switch to CM12s
  17. arvindautar
    Eclair Jul 28, 2015
    arvindautar , Jul 28, 2015 :
    Download wugfresh root tool kit http://www.wugfresh.com/brt/ . It has a restore everything to cm stock option. Even if your device is softbricked.
  18. Cuuldu
    Donut Jul 28, 2015
    Cuuldu , Jul 28, 2015 :
    The APP recognize my mobile but i can´t Drag the zip file. Any idea?
    PD. I have restarted (Mobile and PC)
  19. solBLACK
    Eclair Jul 29, 2015
    solBLACK , Jul 29, 2015 :
    Did you follow the step where you have to manually put the device into Debugging mode again? Mine booted up into OxygenOS again, but after doing that it went and finished installing CM12S.
  20. evilriq
    Gingerbread Jul 31, 2015
    evilriq , Jul 31, 2015 :
    Hi.
    Thanks for this. Just installed Oxygen and it was so easy. :D
    And will be using this again if I don't like Oxygen and want to go back to CM.
