105
[TOOL] OnePlusRecovery Tool | Restore Stock (CM11s) | Fix Bricks | ETC
Thread Status:
Not open for further replies.
  1. SomeSayImHandSome May 22, 2015
    SomeSayImHandSome, May 22, 2015 :
    if you used a toolkit. you had fastboot. this is not meant for that
  2. SomeSayImHandSome May 22, 2015
    do you have fastboot?
  3. furyland Honeycomb May 22, 2015
    furyland, May 22, 2015 :
    What tool did u use? please help
  4. Sh3rl0ck Honeycomb May 23, 2015
    Sh3rl0ck, May 23, 2015 :
    Bricked using this method!
    Phone doesn't power up or vibrate or go to flash boot since then!
    tried this but i don't get any update in the recovery flash!
    Also when i connect my phone, it does not install :
    shows this : Captur1e.PNG
    any help?
    @DaxNagtegaal (Help :( )
  5. DaxNagtegaal Marshmallow May 23, 2015
    Sh3rl0ck likes this.
  6. SomeSayImHandSome May 23, 2015
    SomeSayImHandSome, May 23, 2015 :
    leave usb plugged in phone and pc. and hold power and volume up until you hear connect sound on pc and let go. see if it changes. are you using the stock usb cable? if not use it. if you are try another usb port or another cable
  7. Sh3rl0ck Honeycomb May 23, 2015
    Oh i got it working!
    Problem was Pirated Windows OS and Qualcomm Drivers (I guess)
    Tried on a PC with genuine version of windows and it worked like a charm!
    thanks anyway :)
  8. SomeSayImHandSome May 23, 2015
    i uploaded signed qualcomm drivers around the forums somewhere. everyone should just use those. but good deal
  9. Tricky Ice Cream Sandwich May 24, 2015
    Tricky, May 24, 2015 :
    Any hopes of porting it to Linux?
  10. Shermy Wormy Eclair May 29, 2015
  11. sharun Eclair May 31, 2015
  12. solleks Honeycomb Jun 1, 2015
    solleks, Jun 1, 2015 :
    sorry for what may be a stupid question but I read quite a bit and maybe I missed it but it says if your phone is not detected don't go into fastboot mode but into Qualcomm USB debugging mode what is the button sequence to enter that mode I can't find it? Is it the same power + vol up? Thanks
  13. realdjessence Froyo Jun 11, 2015
    realdjessence, Jun 11, 2015 :
    I need some serious help..my One plus stopped booting up this afternoon...if i turn it on and off it says powered by andriod with the 1+ logo but will not go any further can someone please help me
  14. EmasEmasEmas Donut Jun 12, 2015
    EmasEmasEmas, Jun 12, 2015 :
    I've a problem with the identification of device. I followed all instruction, installed all drivers (coloros and qualcomm), rebooted PC and Recovery tool don't recognize the OnePlus One. PC report a qhsusb_bulk when i connect the phone to USB. When I push power up + vol. up PC change the qhsusb_bulk on Forge HS-USB QDloader 9008 (COM8). So i go to Recovery tool and press refresh but nothing appens. What I have to do?
  15. SomeSayImHandSome Jun 12, 2015
    SomeSayImHandSome, Jun 12, 2015 :
    you need the drivers for when device manager says bulk9008 that's why its not working. I don't know why they keep saying use coloros drivers. they don't work. use mine.
    https://www.dropbox.com/s/xm4iq2rtg4rtb38/Qualcomm HS-USB QDLoader 9008 (1).rar?dl=0
    64bit windows only install manually through device manager
    ScorpioPirate likes this.
  16. EmasEmasEmas Donut Jun 12, 2015
    Thanks, I have to unistall Color OS drivers before?
  17. SomeSayImHandSome Jun 12, 2015
    prob not. when you see 9008 in device manager. unzip the drivers with WinRAR. and manually update the drivers and you should be good
  18. EmasEmasEmas Donut Jun 12, 2015
    Nothing to do. I see 9008 (COM6) in device manager, but when I refresh anything happens, the screen stay as it was.
  19. SomeSayImHandSome Jun 12, 2015
    you will see it. but are the drivers installed for it? I don't see your image. right click bulk9008 and click update driver software. then browse to where the you extracted the drivers and install them
  20. EmasEmasEmas Donut Jun 12, 2015
    I've alredy done this. The img should be visible here
