107
[TOOL] OnePlusRecovery Tool | Restore Stock (CM11s) | Fix Bricks | ETC
Thread Status:
Not open for further replies.
  1. vjalchemist
    Cupcake Jun 16, 2015
    vjalchemist , Jun 16, 2015 :
    Thanks @Jamesst20. I downloaded zip file, opened Allx64 and then clicked on dpinst64.exe - after which I got the message 'Ready to use'. But when I click on 'OnePlusRestoreTool(64GB).exe' file (right-click and run as administrator), IT STILL GIVES ERROR "Load Setting xml file failed"
    voks likes this.
  2. vjalchemist
    @crestardfalohun please help
  3. serjortiz
    Cupcake Jul 1, 2015
    serjortiz , Jul 1, 2015 :
    I did it thanks to yall for making the forum. yall saved my skin, I was all depressed and almost trashed it, but after trying a lot it was fixed.
  4. Matrix828
    Cupcake Jul 6, 2015
    Matrix828 , Jul 6, 2015 :
    OK, first of all thank you for this tool!
    Secondly; I cannot get it to work for me. Plugging the phone in gives an "unknown device" in device manager.
    I cannot install any drivers for it since windows says it is already "up to date".
    How can I "force install" different drivers? not even the supplied ColorOS ones work.
  5. eranm5
    Jelly Bean Jul 16, 2015
    eranm5 , Jul 16, 2015 :
    Hello forum!
    Today, after sitting for hours trying to recover my OPO from a coma brick caused by a corrupted bin flash, I ran into this article:
    http://www.androidbrick.com/ultimate-qualcomm-snapdragon-unbrick-guide-snapdragons-are-unbrickable/
    Is this for real? Are all bricks recoverable in our OPOs? Are 290$ motherboard repairs a waste of your money? ^^
    I'd like to hear what you think. I'm not sure I can be confident with every flash I make :D
    P.S for those of you who are wondering, I managed to recover my phone using the OpoRecoveryTool. Had to give up on my Internal Storage but luckily all my data is backed up to Google Photos.
  6. xouvang
    Cupcake Aug 1, 2015
    xouvang , Aug 1, 2015 :
    My phone goes blink.
    Will not power on. Will not vibrate when holding down volume button.
    Driver shows phone is there. When I launch the program it shows COME and when it hit start it turns red. Please HELP!
  7. xouvang
    Cupcake Aug 3, 2015
  8. Susihukka
    Cupcake Aug 3, 2015
  9. elreey
    Cupcake Aug 26, 2015
    elreey , Aug 26, 2015 :
  10. elreey
    This is the best I've found, simple, easy and powerful. I had a hardbricked OPO and fixed it. I cancel my One Plus One repair ticket. Thanks a million for these instructions and downloads
  11. siocnarf13
    Jelly Bean Aug 26, 2015
    siocnarf13 , Aug 26, 2015 :
    If i'm running TWRP + Exodus rom, will this restore to stock recovery + stock CM so i'll be able to update to COS 12.1 ?
    or can I install COS 12.1 ( latest update ) via TWRP ?
  12. mundaka_surfer
    Eclair Aug 26, 2015
  13. Mr. James
    Eclair Aug 30, 2015
  14. Lotte van wallendael
    Cupcake Aug 31, 2015
    Lotte van wallendael , Aug 31, 2015 :
    @wem97
    Hi!
    I've a problem and I saw you gave a lot of advice so I hope you can help me!
    Yesterday I installed CM12.1 (there was an update) but after he downloaded this new version and he was restarting, he didn't start at all. He just got till the Oneplus logo and got stuck. I went to the recovery mode and tried evertything, like remove the date etc. and then tried to reboot always but it got again stuck at the OnePlus logo screen. If I try the fastboot it'll stuck at the fastboot screen. I saw your post about OnePlus One Recovery Tool, so I installed it but my computer doesn't find my phone. Can you help me with this problem?
    Many many thanks!
  15. bakou
    Cupcake Sep 1, 2015
    bakou , Sep 1, 2015 :
    same here, is it normal ?
  16. mundaka_surfer
    Eclair Sep 1, 2015
  17. rperiasamy
    Froyo Sep 3, 2015
    rperiasamy , Sep 3, 2015 :
    I running the recovery tool but it is not getting past 8794_msimage.mbn. I started the recovery tool as administrastor. I am on windows 7. Help help help!!!
  18. xouvang
    Cupcake Sep 5, 2015
  19. qander
    Cupcake Sep 9, 2015
    qander , Sep 9, 2015 :
    Please help, my phone doesn't works. Will not vibrate when holding power button.
    Driver shows phone is there. When I launch the program it shows me this Безымянный.jpg Безымянный1.jpg
  20. voks
    Cupcake Sep 13, 2015
    voks , Sep 13, 2015 :
    I get the same error message "Load Setting xml file failed" when trying to run it as administrator. The tool starts without problems if not running as administrator, but it doesn't recognize the phone then.
    I didn't run any dpinst64.exe, just extracted the rar file and ran Setup.exe in Drivers folder before trying to start the tool. I'm on Windows 7 64 bit.
    EDIT: I was able to start the tool as administrator when using plain Windows explorer (tried it in FreeCommander before, when the error appeard). But the tool doesn't recognize my phone, when starting it with Volume Up+Power.
