54
[TOOL] OnePlusRecovery Tool (V1.0) | Restore Stock (CM11s) | Fix Bricks | ETC
Thread Status:
Not open for further replies.
  1. Thadjuse22
    Froyo Jan 10, 2015
    Thadjuse22 , Jan 10, 2015 :
    Original post by Zyxxeil on XDA Developers.
    This is useful for all those who bricked their phones and can't get into recovery nor fastboot.
    Hey guys, I am posting this in hopes that it will solve your problem now or in the future. This is basically a modified Msm8974DownloadTool that includes the CM11s (XNPH44S) ROM rather than the color OS ROM (Skipping the whole fastboot flash step and just using this program) as well as its 85% translated (Making it easier to use). This will fix any bricks that you might have gotten yourself into or if you simply want to restore to the stock CM11s firmware. Hope you guys enjoy [​IMG]
    NOTE: (THIS MEANS READ)
    1.) RUN PROGRAM AS ADMINISTRATOR (OR IT WILL FAIL)
    2.) If windows 8 nags that it might be unsafe just click more info and click RUN ANYWAY. (Reason: I modified the exe file to flash CM11s rather than Color OS and it causes it to loose the signature.)
    3) If drivers don't work or your device is not detected for whatever reason install the QPST tool.
    Instructions
    1.) Connect your phone to your PC.
    2.) Make sure the OnePlusRecoveryTool is open and your PHONE IS OFF.
    3.) Hold Volume UP + Power
    4.) Your computer should detect it (If not then install proper drivers, Look below)
    5.) Click Refresh - Something should be different on one of the columns of the program.
    6.) Click Start (Make sure Normal Restore is ticked)
    7.) It should flash (It might take a long time to flash System.img and or Userdata.img sometimes)
    8.) It will show green once its done, at this point you can disconnect device and hold power to reboot.
    9.) You should be fully restored to stock CM11s. Enjoy [​IMG]
    Video on how to use:
    Changelog
    Code:
    v1.1
    Fixed Radios
    Fixed Duplicate Flash (16GB Only)
    Drivers Extracted By Default
    Updated Drivers
    v1.0
    Initial Release
    Note: You may not be to the point where you need this tool yet. If you are just trying to fix issues coming from Oneplus's ROM, then this threadmay be able to help you before you go ahead with wiping everything.
    Download
    Mega.co.nz
    Basketbuild
    AndroidFileHost
    MSM Drivers: Run the setup file located in the Drivers folder and follow the prompts BEFORE using the tool otherwise it will fail.
    WARNING: The Radios issue was addressed in the v1.1 update, but just in case I have provided instructions below on how to manually flash your modem/radio.
    After booting into CM11S, download XNPH44S-modem.bin. Then reboot back to fastboot, cd to the .bin file and flash using:
    Code:
    fastboot flash modem XNPH44S-modem.bin
    macem29, Aftab7860, farmo and 51 others like this.
  2. peteryu
    KitKat Jan 10, 2015
    lnxpro, Dhrumin226 and Hangman88 like this.
  3. finaldentiny
    Community Veteran Jan 10, 2015
    lnxpro and Dhrumin226 like this.
  4. carbine30
    Marshmallow Jan 10, 2015
    lnxpro, Dhrumin226 and TheCount like this.
  5. matanwei
    Gingerbread Jan 10, 2015
    ronclon and lostLambda like this.
  6. pa5t1s
    User of the Year 2014 Jan 10, 2015
    Dhrumin226 likes this.
  7. zeus.01.01.01.01
    Lollipop Jan 10, 2015
    zeus.01.01.01.01 , Jan 10, 2015 :
    good work! relief for those who bricked their device or for those who want to switch back to cm11s but don't know how to..
    thanks!
  8. tyler539
    Jelly Bean Jan 10, 2015
    tyler539 , Jan 10, 2015 :
    Sure a lot of people want this that are testing Lollipop and decide its not for them!
  9. esaurabh
    Ice Cream Sandwich Jan 10, 2015
  10. brittonraya
  11. mihirmwd
    mihirmwd , Jan 10, 2015 :
    Thanks for sharing...
  12. Param Kharoud
    Marshmallow Moderator Jan 10, 2015
  13. vissup9
  14. sh3llshock
    KitKat Jan 10, 2015
  15. lostLambda
  16. B4kken
    B4kken , Jan 10, 2015 :
    Cool :) I get the feeling that bricks are becoming usual around here so this is great!
  17. Pumaeu
  18. gauravsrjalan
  19. kman48
    Froyo Jan 10, 2015
  20. nirmitmehta
