15
[Toolkit] Wug's Bacon Root Toolkit v1.0.2 [Updated 11/24/14]
  1. havoc23
    Honeycomb Jan 9, 2015
    havoc23 , Jan 9, 2015 :
    So were you able to return to stock after using this?
  2. Edbit33
    Jelly Bean Jan 9, 2015
  3. sg01fc
    Gingerbread Jan 9, 2015
    sg01fc , Jan 9, 2015 :
    At first, no. I finally found a post that pointed me in the right direction. Basically, I had to flash a OnePlusOne_BootUnloader.zip that got it back to where it said my phone was unlocked. After that, this worked perfectly.
    havoc23 likes this.
  4. kman48
    Froyo Jan 9, 2015
  5. anzi2001
    anzi2001 , Jan 9, 2015 :
    Great tool. Used it on my nexus 7 woth nexus root toolkit and its awesome :D
  6. a212
    Cupcake Feb 5, 2015
    a212 , Feb 5, 2015 :
    Have you tried using the Outlook app?
  7. Muio Zenin Lay
    Donut Feb 5, 2015
    Muio Zenin Lay , Feb 5, 2015 :
    Please, help me...
    I am a newbie to oneplus.
    I cant install cm12 zip on my OPO with TWRP.
    It shows E: verification failed! How can I do that...?? Thnz :)
  8. Hampa_D
    Jelly Bean Feb 12, 2015
  9. macem29
    Jelly Bean Mar 20, 2015
    macem29 , Mar 20, 2015 :
    searched first, a few mentions of this kit, but no threads specifically about it,
    and no place listed to download it....credit of course to the maker @WugFresh
    I know some don't like tool kits and suggest you learn ADB terminal commands,
    meh, not sure i want to do that, so I've looked at the various toolkits and really like
    this one. It does the usual stuff, unlock bootloader, root, flash stock ROM etc.
    Also has a great feature to ensure correct ADB drivers and USB drivers get installed,
    and tests for proper connectivity. Essential things for someone who wants to play.
    http://www.wugfresh.com/brt/
    ashishjena and vinay.k.21 like this.
  10. kadowson
    Ice Cream Sandwich Mar 20, 2015
  11. DaxNagtegaal
    Marshmallow Mar 20, 2015
    DaxNagtegaal , Mar 20, 2015 :
    Toolkits are great until they a) screw up and brick your phone or b) something else goes wrong, and you don't know how to fix it because you have absolutely zero experience with fastboot or adb because the toolkit did it all for you.
    Don't be a lazy shit and put a few hours into learning adb/fastboot
  12. addam
    KitKat Mar 20, 2015
    addam , Mar 20, 2015 :
    The link is in my signature as well, its a good toolkit to have if you get in trouble
  13. jizang
    Lollipop Mar 20, 2015
  14. macem29
    yep, that's how I got BL unlocked and rooted at first
    then ADB stopped working, no idea why, and messing with drivers did not solve it
    this toolkit, with it's ability to work though that fixed it for me, so now i can play and
    have confidence that when I boot loop it (happened once already) I'll be able to
    connect and fix it
  15. vinay.k.21
    vinay.k.21 , Mar 20, 2015 :
    Good for people who know about adb/fastboot... but too lazy to go through it again...
    Used this to root my phone by the way...
    addam, DaxNagtegaal and dgdfgsdfgsg like this.
  16. flamingodise
  17. ljstreak
    Eclair Mar 28, 2015
    ljstreak , Mar 28, 2015 :
    Really this is a wonderful tool,,,But donno y the gadget geeks ignored this to the core...This should be recommended to all who less experienced in these, tech is for simplifying things, i belive so..
  18. pa5t1s
    User of the Year 2014 Mar 28, 2015
    #38
  19. ariya
    Donut Mar 28, 2015
    ariya , Mar 28, 2015 :
    Great toolkit, from a great peace of work. Used for nexus 5, and rooted my + whit it.
    Working like a charm!
    #39
  20. ariefun123
    Honeycomb May 21, 2015
    #40
