63
Top Technical Questions Answered - May Edition
  1. Vengatalakshmi
    Cupcake Jun 11, 2020
  2. rhyd1am
    Jelly Bean Jun 11, 2020
    rhyd1am , via OnePlus Community App , Jun 11, 2020 :
    I've just been looking on the OnePlus site. It says it of stock at the moment, but if you go to the website there is an option on there, to ask them to let you know when it's back in stock.
    Vengatalakshmi likes this.
  3. Vengatalakshmi
    Vengatalakshmi , via OnePlus 7T , Jun 11, 2020 :
    Will Oneplus 5G supports networks globally or region-wise only?
    Lets say, If I purchase a OnePlus 8 Pro from Middle East, Can I use that phone in Indian 5G networks ? Or is there any country lock for 5G network?
    Ps : I read that there are lock in some customer reviews. That's why!
  4. Vengatalakshmi
    rhyd1am likes this.
  5. Vengatalakshmi
  6. rhyd1am
    Vengatalakshmi
    Ps : I read that there are lock in some customer reviews. That's why!​
    That's a question you'd have to ask OnePlus themselves and your particular network provider. Im in the uk myself, so i can't really answer that with confidence
  7. Vengatalakshmi
    Yup I will try asking them. I appreciate you for clearing the queries.
    rhyd1am likes this.
  8. rhyd1am
  9. rhyd1am
    Yes the option is under settings>display>screen refresh rate
  10. pandas_get_good
    Cupcake Jun 12, 2020
    pandas_get_good , Jun 12, 2020 :
    thank you so much!!! that fixed it!! for real who would think this would be a useful feature? they should make this a default setting honestly
  11. 770016
  12. Vengatalakshmi
  13. J1585090666932
    Eclair Jun 13, 2020
    J1585090666932 , via OnePlus 7T Pro , Jun 13, 2020 :
    There are popup messages for notifications. They are located in notification settings. Regarding the Bluetooth volume, you want to disable Bluetooth absolute volume in the Bluetooth settings, which syncs the phone volume to the Bluetooth one.
  14. J1585090666932
    Eclair Jun 13, 2020
    The link in the thread for phone heating leads to black screen issues instead.
    Furthermore, I looked over what was posted for Bluetooth devices, but didn't see my particular issue. I use Apple AirPods (Gen 2) and after taking a phone call with my OnePlus 7T Pro phone via Telegram and potentially others, I cannot get back to listening music. I need to put the AirPods back in the case and reconnect them. Resetting Bluetooth itself from the phone didn't seem to work last time.
  15. Jaybe1
    Cupcake Jun 13, 2020
    Jaybe1 , Jun 13, 2020 :
    J1585090666932
    There are popup messages for notifications. They are located in notification settings. Regarding the Bluetooth volume, you want to disable Bluetooth absolute volume in the Bluetooth settings, which syncs the phone volume to the Bluetooth one.​
    Thanks. Can you show me what these popups are meant to look like. Does it just popup for a second. I'm used to iPhone where I had a banner stay on the screen until I read the message. I'm getting hard to get used to not having that. I'm finding android very buggy. Sometimes I get no notification sound at all. Now the bubbles have stopped working too for WhatsApp yet it's turned on. I'll try the Bluetooth setting and see if that solves anything with that issue.
    Another bug I found is if you search for something on Google and a video is available for said search. If you press on the YouTube link and turn the phone landscape to view it the video freezes. Have to force close Google as no matter what you do it won't do anything. Try it and see if it happens anyone else.
  16. J1588874213394
  17. J1588874213394
  18. J1585090666932
    Eclair Jun 13, 2020
    Jaybe1
    J1585090666932
    Another bug I found is if you search for something on Google and a video is available for said search. If you press on the YouTube link and turn the phone landscape to view it the video freezes. Have to force close Google as no matter what you do it won't do anything. Try it and see if it happens anyone else.​
    Here it is. You can reply, mark as read or even delete SMS messages from the banners (very useful for codes). I've also attached an example of how you can enable or disable it, but I've never personally had to tweak it manually.
    I definitely don't have any issues with notification sounds.
  19. Artemus.
    Nougat Jun 16, 2020
    Artemus. , Jun 16, 2020 :
    Depends. How much dropping of the phone do you do?
