63
Top Technical Questions Answered - May Edition
  1. Artemus.
    Nougat Jun 16, 2020
    Artemus. , Jun 16, 2020 :
    Then it'll be enough protection for you. Though, if you really want peace of mind, buy a third-party one from Amazon.
  2. Back4More
    Cupcake Jun 17, 2020
    Back4More , via OnePlus 7 Pro , Jun 17, 2020 :
    can I remove the entire gapps application and all Google apps through ADB and my phone still work correctly? everything I need to do I can do with a browser so I would like to stop Google from prying into my device or using my Wi-Fi to scan other places and devices .
  3. Deniskurian
    Cupcake Jun 19, 2020
    Deniskurian , Jun 19, 2020 :
    I send in my onePlus 8Pro for an over-heating issues, its been a month, and still i haven't received a replacement.. When i contacted customer service via the phone, they said they did not have the aquamarine in stock... WOW... That too because i had to call and check my status of my return... I would not suggest anyone else buying the phone... Literally sucks... Brought it on launch day, a month back, i think. Now, when they asked me to return the phone for a replacement, they don't have a replacement... WTH...
  4. nickag
    Cupcake Jun 20, 2020
    nickag , Jun 20, 2020 :
    since my 5t was upgraded to Android 10 the volume of the phone when someone calls is very low..I try to raise it but the best I can do is raise it as much as half of what the volume was previously.
    can you please take a look at this issue
    thanks
    Nick G.
  5. Artemus.
    Nougat Jun 20, 2020
    Artemus. , Jun 20, 2020 :
    Is... is your username your phone number?
  6. nickag
  7. E1592681481517
  8. Z1540440738599
    Z1540440738599 , Jun 20, 2020 :
    Hi Tech Team, As my 1+5T recently updated with OS10, I am facing some issues like I m unable to open pdf files, which I have open earlier second issue is whenever I change switch data card either from 1 to 2 or vice versa my net didn't started, to start net I have to restart my phone. Both above mentioned issues I m facing only after OS10 update.
    Requesting Tech Team to look into the matter and resolve this ASAP.
    Rgds,
    TDK
  9. U1519659728737
    Cupcake Jun 21, 2020
    U1519659728737 , Jun 21, 2020 :
    the op bullet wireless z is getting audio delay while playing games even if I connected to the fnatic mode . as I bought it for the gaming it turn out to be worst buy, is there anything I can fix this delay..... ?
  10. M1592743376043
    Cupcake Jun 22, 2020
    M1592743376043 , Jun 22, 2020 :
    hello, can anybody help me to guide how can i change launcher layout? i tried tha apps from homescreen but want to go back to previous settings.
  11. rhyd1am
    Jelly Bean Jun 22, 2020
    rhyd1am , via OnePlus Community App , Jun 22, 2020 :
    Long press on an empty space of the home screen>home settings>launcher layout
    Artemus. likes this.
  12. the__sanskar
    the__sanskar , Jun 22, 2020 :
    Earlier there was an option to edit the slow motion video but after the update i received this week it's gone! Now the whole video is slow motion and I can't do a thing about it! Why did you do that #Oneplus? why?
  13. Z1592817010689
    Z1592817010689 , Jun 22, 2020 :
    facing a lot of issue with this new android 10 update in my oneplus 5T phone getting hanged alot.previous version was more more better than the new one. hope.oneplus might solve these issue ASAP.
  14. Artemus.
    Nougat Jun 22, 2020
    Artemus. , Jun 22, 2020 :
    One word: format.
    rhyd1am likes this.
  15. D1543639932741
    D1543639932741 , Jun 22, 2020 :
    Hi
    my speaker or microphone is not working.. I don't know what goes inside bt not audible anything clearly
  16. Z1592817010689
    Cupcake Jun 23, 2020
  17. Javier1396
