61
Top Technical Questions Answered
  1. W1574198278837
    Cupcake May 22, 2020
    W1574198278837 , May 22, 2020 :
    I can't seem to update/install apps from Google play store. it's takes hours to update/install an app. Not receiving any notifications either. Please help. I have wiped cache.
    OnePlus 7 Pro
    IMEI 1: (Removed by Mod)
    Build Number: Oxygen OS 10.3.1.GM21AA
  2. S1590190562161
    Cupcake May 23, 2020
  3. S1590190562161
  4. jhoon_09
    Eclair May 23, 2020
  5. rohitsandhu6582
    Donut May 23, 2020
  6. bezil13
    Eclair May 25, 2020 at 5:35 PM
  7. DominicMalomvari
    Cupcake May 25, 2020 at 5:44 PM
    DominicMalomvari , via OnePlus 8 Pro , May 25, 2020 at 5:44 PM :
    It is advisable to use a USB type C cable to connect my OnePlus 8 pro to my car to use Android Auto? Will it damage the battery life as I am not using OnePlus 8 pro warp car charger. To use Android Auto I have to connect a USB type C cable to my car then plug the lead in my OnePlus 8 pro. Can you suggest what to do. Many thanks.
  8. E1553935551758
    Cupcake May 28, 2020 at 12:35 PM
  9. Hhslat
    Cupcake May 28, 2020 at 6:22 PM
    Hhslat , May 28, 2020 at 6:22 PM :
    Just got a 7t to replace my 6t but having issues with notifications coming through and issues with yahoo mail - the mail app doesn't sync over WiFi and when I manually refresh and see the message, it hangs and won't show any content. it works on 4G though.
    App and WiFi settings identical on both phones but 6t works perfectly.
    Help!
  10. Q1590699492196
    Cupcake May 28, 2020 at 10:01 PM
