3
Touch Lags & latency on OP3
  1. Navneet Bhargava
    Honeycomb Jun 5, 2017
    Navneet Bhargava , Jun 5, 2017 :
    U install new rom download from oneplus site or just wipe cache.
    If not just download new rom what ever u want and install using abd method and dont forget to wipe data under recovery menu.
  2. Navneet Bhargava
    If still doesn't solve problem.
    Seems like it's has a hardware issue
    Book a ticket and visit near oneplus customer care.
  3. hbmehta1992
    Eclair Jun 5, 2017
    hbmehta1992 , Jun 5, 2017 :
    Guys...This is the snap of pointer overlay of my OP3 which clearly shows that it is not detecting touch in the middel horizon of the screen...
    let me know if this is hardware issue!
  4. asasione
    Ice Cream Sandwich Jun 5, 2017
    asasione , Jun 5, 2017 :
    That might be a hardware issue, go get it checked out at a service center
    hbmehta1992 likes this.
  5. lars.lange
    Cupcake Jun 5, 2017
    lars.lange , Jun 5, 2017 :
    I had this sort of problem on my tablet but there it was because of the lag of android sometimes it worked perfect sometimes it was like your screenshot. Had your phone been in direct sunlight for a long time maybe the digitizer is broken kinda .
  6. G_Faizul_Rabbe_TzLy
    Cupcake Jun 5, 2017
    G_Faizul_Rabbe_TzLy , Jun 5, 2017 :
    I get the same problem, also when I try to unlock the phone using finger print it hangs, so I either have press fingerprint multiple times or unlock it using pin but after that it hangs for a while
  7. theonly2333
    Eclair Jun 5, 2017
    theonly2333 , Jun 5, 2017 :
    Go use a reboot.
    It may help sometimes. If the problem persists, then you may need some other help such as hardware check
  8. anandbibek
    Gingerbread Jun 5, 2017
    anandbibek , Jun 5, 2017 :
    Clearly a hardware problem. If you're not in warranty period, it's gonna cost a huge amount to replace the digitizer
  9. hbmehta1992
    Eclair Jun 5, 2017
    My OP3 is still in warranty
  10. hbmehta1992
    Eclair Jun 5, 2017
    i did factory and hard reset twice.. reboot multiple times..but still the issue persists
  11. Punith.yadav
    Cupcake Jun 5, 2017
    Punith.yadav , Jun 5, 2017 :
    Even i facing the same touch sensitivity issue especially on the lower part of the screen..
    few threads suggested to turn off all gesture , i tryed that to but its not helping ..
  12. G_Shams_Rehan_NxCz
    G_Shams_Rehan_NxCz , Jun 5, 2017 :
    Good to see, that i am not the only one with touch screen latency. It has not been fixed yet and it's very disappointing. Sad.
  13. SJBoss
    Lollipop Jun 5, 2017
    SJBoss , Jun 5, 2017 :
    i would recommend you to contact OnePlus customer support as it seems like an hardware failure
  14. SJBoss
    contact OnePlus customer support as it seems like a hardware issue.
  15. mayurparmar013
    Cupcake Jun 5, 2017
  16. Charlesjung9182
    Gingerbread Jun 6, 2017
  17. go8soccer
    Ice Cream Sandwich Jun 6, 2017
  18. adpro
    KitKat Jun 6, 2017
    adpro , Jun 6, 2017 :
    Did you try using phone on safe mode yet?
    If not, it's worth giving it a try.
    At least you will find out if third party apps are the reason.
    #38
  19. F_Diganta_Koner_WIXu
    Jelly Bean Jun 6, 2017
    #39
  20. hbmehta1992
    Eclair Jun 7, 2017
    hbmehta1992 , Jun 7, 2017 :
    Finally..It's a hardware issue and got screen replaced..Now my OP3 is working fine :)
    #40
