Touch sensitivity Issue... via OnePlus 8 Pro
  1. M1614948932694
    Cupcake Aug 9, 2021
    M1614948932694 , via OnePlus 8 Pro , Aug 9, 2021 :
    Hey team I had recently applied a 3d tempered glass for my OnePlus 8 pro... But I am getting some sort of touch sensitivity issue... I have to click on any application 2 to 3 times... As I need to do day to day rask flawlessly... That I cannot do it... Can u please give me some solution for this...
  2. J4t1np4r3kh
    OnePlus Accessory Tester Aug 9, 2021
    J4t1np4r3kh , Aug 9, 2021 :
    Given it started once you applied the 3D tempered glass, I would get rid of it. That should solve your problem.
    Try look for another screen protector instead
    Aaron2017 likes this.
  3. O1633337076445
    Cupcake Oct 20, 2021
    O1633337076445 , via OnePlus 9 , Oct 20, 2021 :
    Hey,
    I have been facing serious touch response issue with tempered glass. Rn I am using spigen tempered glass meant for OP9. As I type this too .. I am applying alot of force to be using this and response is bad. I have seen this issue being mentioned on community by many users. Please tell me how to get this fixed . Or if in case OP is addressing this issue. I have tried 3 different brand tempered glasses till now.. same works absolutely fine on my friends OP8 . This phone of mine is brand new. Been only like 10 day's..
  4. J4t1np4r3kh
    OnePlus Accessory Tester Oct 20, 2021
    J4t1np4r3kh , Oct 20, 2021 :
    As you have said, many users are facing this issue, I would suggest to not use a thicker screen protector, and opt for a thinner one instead.
  5. O1633337076445
    It isn't something to do with thickness as the same works absolutely okay with OP8T mobile .
  6. J4t1np4r3kh
  7. O1633337076445
  8. J4t1np4r3kh
    Then there isn't much you can do I guess.
    You could try report it, and provide your feedbacj
