11
Touch Sensitivity Issues [OFFICIAL RESPONSE]
  1. PR0X
    Ice Cream Sandwich Apr 15, 2015
    #61
  2. shethvivek
    Cupcake Apr 15, 2015
    shethvivek , Apr 15, 2015 :
    Same issue, and no workaround is fixing anything.
    The phone has been with one plus service centre and they are just behaving as erratic.
    Its a worst buy ever, and I am so frustrated. :( :(
    #62
    House_Maniac likes this.
  3. funknflex
    Cupcake Apr 18, 2015
    #63
  4. kev3592
    Cupcake Apr 19, 2015
    #64
  5. Twiz1
    Honeycomb Apr 19, 2015
    Twiz1 , Apr 19, 2015 :
    I started having touch screen issues tonight
    Can't allow my phone to lock:( otherwise the swipe doesn't respond and when it does, the numbers on the keypad don't respond
    #65
  6. Tr1p
    Gingerbread Apr 19, 2015
    Tr1p , Apr 19, 2015 :
    This ain't working for me .....
    #66
  7. subham singh
    Donut Apr 19, 2015
    #67
  8. cold_as_ice
    cold_as_ice , Apr 19, 2015 :
    when did you buy your opo?
    #68
  9. Twiz1
    July 2014
    Crazy thing with mine also. When touchscreen starts to act up, so do the capacitive buttons, they stop responding.
    #69
  10. rothkevin
    Donut Apr 22, 2015
    rothkevin , Apr 22, 2015 :
    I've had touch sensitibity issues for about two months now. It started back when i was using CM11.
    Scrolling is buggy when dragging from the middle of the screen, and the phone has a hard time registering what keys im pressing. Especially "t's" and letters close to it.
    I thought that upgrading to CM12 would fix it but it didn't.
    Let's see if disabling gestures works (sorry but i doubt it).
    #70
  11. malidan
    Marshmallow Apr 22, 2015
    malidan , Apr 22, 2015 :
    Did you really think it would.
    From day one there has always been 2 issues.
    1. The Yellow band
    2. The touch screen
    Neither have been fixed and never will.
    The OP2 is almost here so they have managed to get away with murder.
    #71
    PR0X likes this.
  12. giannis1985gr
    Donut Apr 26, 2015
    giannis1985gr , Apr 26, 2015 :
    I also have the same issue as all of you but with this tip it looks like that it work better than before.i was ready to go to 44s from Cos 12 to see if this is the fault cause i never had this issue before.i ll give it a try.thanks
    #72
  13. chillalex
    Cupcake May 12, 2015
    chillalex , May 12, 2015 :
    Do you use the gestures and the double-tap? Is the "Show touches" tip the solution so we can use double-tap and the gestures again?
    #73
  14. wrezanoor
    Gingerbread May 12, 2015
    wrezanoor , May 12, 2015 :
    Yes. That happens.
    #74
  15. wrezanoor
    Yes. That happens.
    #75
  16. hammet
    Donut May 12, 2015
    hammet , May 12, 2015 :
    I use double-tap yes. But not gestures...
    But the double-tab is working fine...
    So I think you should try my tip.
    #76
    chillalex likes this.
  17. chillalex
    Cupcake May 15, 2015
    chillalex , May 15, 2015 :
    So far it works fine with the double-taps. I have my gestures off, too. Thank you for the tip, buddy ;)
    #77
  18. eatkabab
    Cupcake Jun 29, 2015
    eatkabab , Jun 29, 2015 :
    I've had two of these phones so far. The first touch screen was fine for 4 months then it crapped out and lost all sensitivity and accuracy. Now they've replaced it and I always turn off all nifty features. Just use basic phone and didn't touch the software at all. AGAIN the screen crapped out at 4 months. On the previous phone I tried every hack, crack, rom, reformat, everything to get it to work again but it never did. When I got the new phone it was excellent for exactly 4 months almost to the day. I've contacted support again but I suspect they won't do anything since I'm one week outside warranty. I'll never buy another "oneplus" again. This is awuful. I've had to go back to my galaxy S3 with a 3hr battery life because I can't type at all anymore.
    #78
