6
[Submitted] Touchscreen and multi touch issues
  1. eduardeutsch
    Eclair Jul 15, 2019
    eduardeutsch , Jul 15, 2019 :
    There are some Touch issues with the OnePlus 7. While pinch to zoom and holding my thumbs, on Google Maps for example, the map goes crazy. With thumbs touching together, they gets recognized many times (as false imput, tested on the multi touch test app). Problems like that happens in various situation when holding thumb/s on the screen (like gestures etc). Seems like ghost touch issue. Attached some videos to prove the issue. Here a previous discussion: https://forums.oneplus.com/threads/oneplus-7-touch-issues.1070754/#post-20548934
  2. tagilso
    Eclair Jul 15, 2019
  3. G_Andreas_Glatz_YMJL
    Froyo Jul 15, 2019
    TVTV, tagilso and eduardeutsch like this.
  4. eduardeutsch
    Eclair Jul 15, 2019
    It will be a good thing to understand if it's a sw or hw problem. Engineering mode screen test says its ok. Dunno, on what OOS version are you?
    TVTV likes this.
  5. tagilso
    Eclair Jul 16, 2019
    tagilso , Jul 16, 2019 :
    OOS 9.5.6.
    Engineering mode touchscreen test says PASSED.
    Manufacturer is Samsung.
    TVTV likes this.
  6. eduardeutsch
    Eclair Jul 17, 2019
    eduardeutsch , Jul 17, 2019 :
    Got a new OP7, no problem on 9.5.3
    Then updated to 9.5.6 and guess whos back? Same issue on the new one. At least seems like a SW issue now..
    TVTV and tagilso like this.
  7. tagilso
    Eclair Jul 17, 2019
    tagilso , Jul 17, 2019 :
    Good news!
    Let's hope OnePlus will sort this out.
    TVTV likes this.
  8. tagilso
    Eclair Jul 19, 2019
    TVTV and eduardeutsch like this.
  9. eduardeutsch
    Eclair Jul 19, 2019
    eduardeutsch , Jul 19, 2019 :
    I flashed a LineageOS test build found on xda, no problem at all... meh
    Can you confirm this issue won't happen with a case on the device?
  10. tagilso
    Eclair Jul 19, 2019
    tagilso , Jul 19, 2019 :
    I've always had the official case on during my tests.
    It does not make any difference with or without the case.
  11. eduardeutsch
    Eclair Jul 21, 2019
  12. tagilso
    Eclair Jul 29, 2019
    tagilso , Jul 29, 2019 :
    got a reply from a OnePlus bug hunter.
    "We're working on this, once we have an update, I'll let you know for sure."
  13. TVTV
    Gingerbread Jul 29, 2019
  14. ascent
    Honeycomb Aug 1, 2019
  15. Y1567328209885
    Cupcake Sep 1, 2019
    Y1567328209885 , Sep 1, 2019 :
    Same problem here on OOS9.5.8.
    Also noticed that this problem only occurs to me in specific conditions; When environment temperatures rise above approximately 25 degrees Celsius. And when I touch the bottom housing of the phone with another finger. When I only hold the sandstone case and use two fingers to touch, the problem doesn't occur to me.
    X1562067010189 and eduardeutsch like this.
  16. insan_1
    Cupcake Sep 3, 2019
  17. nexuspur
    Eclair Sep 7, 2019
  18. Ananth.sidgam
    Cupcake Sep 17, 2019
    Ananth.sidgam , Sep 17, 2019 :
    my OnePlus 6 device is having the same issue from the past one month.
    please suggest a solution
  19. U1560455998283
    Cupcake Sep 19, 2019
  20. Y1567328209885
    Cupcake Sep 23, 2019
    Y1567328209885 , Sep 23, 2019 :
    Updated my OnePlus 7 yesterday to Android 10 (OOS 10.0.GM57AA and the problem still persists.
