61
Touchscreen issues - Fix
Please do vote so that we can check the number of Fixes as well :)
  1. Yes my touch screen issues are Fixed :)
    326 vote(s)
    43.0%
  2. No, I am still facing touch issues after following the steps :(
    432 vote(s)
    57.0%
  1. Sanam S
    Gingerbread Jun 2, 2015
    Sanam S , Jun 2, 2015 :
    Hello Everyone,
    As we all know that there are some touchscreen issues with OnePlus One and as promised by @Carl that we will be releasing a fix for this issue. So here we are with a fix for Ghost Touch and Ghost Swipe issue. Please note that this fix will install Oxygen OS on your phone and this fix is currently working only with Oxygen OS. Build Date May 27 2015.
    This may fix other touch screen issues as well therefore I would suggest you all to try this new Build.
    Note ---
    1. Please backup your device data as the phone will be formatted completely.
    2. Complete Wipe is mandatory for the fix to work properly.
    3. This will only work for Windows Machine. For Mac and Linux users, please contact us through the ticket and we will help in flashing your device. :)
    4. BootLoader will remain unlocked after this Fix.
    Steps :-
    1. Please Download the Fix and extract it on your Desktop.
    2. Power Off your ONE and make sure that USB cable is not connected.
    3. Now press and Hold Volume UP and Power Button and your device will enter into Fastboot Mode.
    4. Once in Fastboot mode, Please connect your device to your computer, usually the drivers will be loaded automatically. If not then please install the drivers manually. (Follow the link below)
    5. Now open "ONEPLUS ONE - 0.bat", you will see a black screen with some numbers on it, that means that the device is connected and drivers are loaded successfully., if not then please install the drivers manually.
    6. Now open "ONEPLUS ONE - 1.bat", If your device restarts then repeat the steps 2,3,4,5 and 6. However if your device doesn't reboot then please go to Step 7.
    7. Now open "ONEPLUS ONE - 2 - 16GB.bat" or "ONEPLUS ONE - 2 - 64GB.bat" depending upon your device.
    8. Once it is completed, your device will restart, please go ahead and test your device.
    Links :-
    Ghost Touch Fix -
    https://s3.amazonaws.com/oneplussupport/ONEPLUS ONE-Ghost Touch-Windows.zip
    Driver Installation Guide -
    https://s3.amazonaws.com/oneplussupport/ONEPLUS ONE DRIVER INSTALLATION.pdf
    yowchang, nTECHIE, natheux and 58 others like this.
  2. Deactivated User
    Jun 2, 2015
    DeltaSky and Ceasedd like this.
  3. script
    Moderator Moderator Jun 2, 2015
    script , Jun 2, 2015 :
    I believe this is a very important sentence :)
  4. feluda
    Lollipop Jun 2, 2015
    adamto, gaster, script and 1 other person like this.
  5. Farazahmed7
    Ice Cream Sandwich Jun 2, 2015
    isaaccallan likes this.
  6. PRK.R
  7. landenone
    Honeycomb Jun 2, 2015
    landenone , Jun 2, 2015 :
    This. It should be highlighted better.
    blake15429, Ceasedd and script like this.
  8. Maximus Decimus Meridius
    Maximus Decimus Meridius , Jun 2, 2015 :
    Thanks @Sanam S please sticky thread (at least for a short while) :)
  9. PRK.R
    PRK.R , Jun 2, 2015 :
    Its already sticky.;)
    gaster and Ceasedd like this.
  10. gmo8492
  11. daedal
    daedal , Jun 2, 2015 :
    does oxygenOS in this fix come somewhat updated, or is it same version launched in April only with new touch panel firmware ?
    blake15429, script and Jorge48197 like this.
  12. gusuraman
    Community Veteran Jun 2, 2015
    gaster, Ceasedd and finaldentiny like this.
  13. A.S
    A.S , Jun 2, 2015 :
    Smart way to make people install your own OS rather than cyanogen in order to solve one of the most annoying bugs in the opo:rolleyes:
  14. prashant sahni
    Jelly Bean Jun 2, 2015
    prashant sahni , Jun 2, 2015 :
    My device had touch issues earlier & had been in communication with OnePlus team & HCL india team. My device was sent to HCL Bhopal service center, they did the procedures & my device was loaded with Oxygen OS. Its been more than 40 days & my device has been working perfectly, even in Nagpur Summers. I did a thorough check by keeping my device in pocket with screen facing inwards for more than 30 minutes on various days @45° C. This definitely solved my issues. I think CM was never serious enough to solve the issue
  15. MagicMagicD
    MagicMagicD , Jun 2, 2015 :
    Can you confirm that if a "complete wipe is mandatory for the fix to work properly" then the next update for Oxygen will also require a complete wipe?
  16. Sanam S
    It is a latest build with new firmwares. Build date is May 27 2015
  17. prashant sahni
    I had enquired with the service center n they affirmed that complete wrote in necessary
  18. prashant sahni
    My device was handled by service center team on 18 & 19th April, even that build worked wonders
    ThE_MarD85 likes this.
  19. finaldentiny
  20. LifelessLewis
    LifelessLewis , Jun 2, 2015 :
    For anybody saying that they're trying to get people to install oxygen over cyanogen. No. Oneplus have no control over cyanogen so they are just trying to fix your phone the best way they can.
