61
Touchscreen issues - Fix
Please do vote so that we can check the number of Fixes as well :)
  1. Yes my touch screen issues are Fixed :)
    326 vote(s)
    43.0%
  2. No, I am still facing touch issues after following the steps :(
    432 vote(s)
    57.0%
  1. fabiosol
    Cupcake Jun 4, 2015
    fabiosol , Jun 4, 2015 :
    I try to reboot yesterday and nothing has changed.... Tonight in airplane mode and safe battery mode, awake of GPService full activity and 15% of battery drain without using in the night.... I think that I try to reinstall everything....
  2. ionut123
    Gingerbread Jun 4, 2015
    ionut123 , Jun 4, 2015 :
    45 days and counting.....
  3. ionut123
    Rolodex likes this.
  4. rarog
    Lollipop Senior Moderator Jun 4, 2015
    rarog , Jun 4, 2015 :
    That sucks. Are you waiting that long for answers? If you want, you could send me a PN with your ticked number and two sentences describing the issues. I could try to escalate this.
    Takendown likes this.
  5. ionut123
    100% agree with you. Magic question is, how many people need to get angry enough about this to start a civil case against @Carl and his whole team? I reckon we're well on the way.
    Rolodex and bombadier like this.
  6. MagicMagicD
    Honeycomb Jun 4, 2015
    MagicMagicD , Jun 4, 2015 :
    I wasn't having any ghost touch problems before but decided to flash this 'update' as a few people had suggested it resolved the Google Play services wakelock. I'm not having any touchscreen issues after (either ghosting or multi-touch) but the wakelock is unaffected.
    I pulled the framework-res after flashing and can confirm it still had the SystemUpdateService(s) disabled, so anyone hoping that it will fix that issue as well, you're out of luck!
    avinashmakam likes this.
  7. Padn1
    Cupcake Jun 4, 2015
  8. Enyalius
    Jelly Bean Jun 4, 2015
    dustbunnyck likes this.
  9. Enyalius
    Enyalius , Jun 4, 2015 :
    Uncheck the "update recovery" in developer options. System updates won't replace your recovery then :)
  10. Enyalius
    Go for Exodus, you won't regret it
  11. fabiosol
    Cupcake Jun 4, 2015
    Screenshot_2015-06-04-10-23-01.png Screenshot_2015-06-04-10-24-03.png Hi all, can anyone tell me if the battery performances are good or not? I'm on Oxygen Os after the 27th may patch. The first day of use after installing update awake time of Google Play service was not persistent like now. What do you think? Thanks
  12. settolo
    settolo , Jun 4, 2015 :
    You have Google Play Service battery drain bug. Your phone does not sleep. Performances are not good. But we are OT here.
  13. jaivaghela
    Ice Cream Sandwich Jun 4, 2015
  14. rarog
    Didn't consider myself having Ghost touch, but now the typing is much more responsive. Thx for the nice kernel and fast development. Got instant donation today. Totally worth it!
  15. rarog
    OTA should come soon. I'm using Boeffla kernel in the mean time. You need to have an unlocked bootloader though.
  16. wmm
    KitKat Jun 4, 2015
    wmm , Jun 4, 2015 :
    If you are in fastboot mode after step 6, you are fine, go on to step 7. I think what they meant was that if the phone fully reboots, i.e., you are not in fastboot mode, you need to repeat the steps.
  17. wmm
    KitKat Jun 4, 2015
    wmm , Jun 4, 2015 :
    It does not relock the bootloader, but it does replace the recovery. Edit the "2" .bat file not to flash the recovery if you want to keep the existing one.
  18. wmm
    KitKat Jun 4, 2015
    wmm , Jun 4, 2015 :
    Okay, thanks for that info. Guess it must have just been a transient from the new installation that it didn't manifest at first. Oh, well...
  19. wmm
    KitKat Jun 4, 2015
    wmm , Jun 4, 2015 :
    Actually, this process will ignore that setting and replace the recovery since the "2" .bat file explicitly flashes the recovery. An OTA will respect that setting, though.
  20. zongyi_e
    Cupcake Jun 4, 2015
    zongyi_e , Jun 4, 2015 :
    ...why Making an update so hard to install, can you make it easier ? I don't want to wipe the phone and install everything back again... Waste of time
