61
Touchscreen issues - Fix
Please do vote so that we can check the number of Fixes as well :)
  1. Yes my touch screen issues are Fixed :)
    326 vote(s)
    43.0%
  2. No, I am still facing touch issues after following the steps :(
    432 vote(s)
    57.0%
  1. daedal
    Gingerbread Jun 2, 2015
  2. Tricksodave
    Jelly Bean Jun 2, 2015
  3. rarog
    Assistant Head Moderator Assistant Head Moderator Jun 2, 2015
    rarog , Jun 2, 2015 :
    That's nonsense. CM and Oxygen can only use the drivers they are provided with. These seem to be the most current drivers and are also tested internally by CM since May 29th and since the nightly 20150602 they are also inside. But this is offtopic in Oxygen thread. And the most important thing is, that this fix DOES seem to work - regardless of used ROM. And it's great to hear from OP, that they have a working solution finally. It's very frustrating if you try to sell something great but something goes wrong because of the component supplier.
    If you want to see the changes - see here:
    http://review.cyanogenmod.org/#/c/99607/
    But I don't think that you can read something from the BLOB driver. ;)
  4. nimish_rathod
    Ice Cream Sandwich Jun 2, 2015
    nimish_rathod , Jun 2, 2015 :
    Thank you very much for this fix
    thanks to carl and sanam s
    ThE_MarD85 likes this.
  5. malidan
    Nougat Jun 2, 2015
    malidan , Jun 2, 2015 :
    I find it amazing that OP has had to release a touch screen fix after they supposedly fixed the issue last year with the fix they released then.
  6. Rick Manders
    Community Veteran Jun 2, 2015
    Rick Manders , Jun 2, 2015 :
    I myself don't have any touchscreen issues, but will this also be an update OTA?
  7. malidan
    Nougat Jun 2, 2015
    Yeah I suppose they couldn't use the fix from last year that was in CM.;)
    A.S likes this.
  8. francois53
    Honeycomb Jun 2, 2015
    francois53 , Jun 2, 2015 :
    For custom rom download AK Kernel fix are in this custom kernel and it works for me (for the moment)
  9. Sanam S
    Sanam S , Jun 2, 2015 :
    If you follow the steps then it will wipe the phone for you :)
    PRK.R likes this.
  10. redvil
    Cupcake Jun 2, 2015
    redvil , Jun 2, 2015 :
    I can't see in last nightly 602 any word about fix are you sure?
  11. nicky3
    Froyo Jun 2, 2015
    nicky3 , Jun 2, 2015 :
    Thank for this "fix"...
    Some questions, I'm in process with your tech and wait for him some days, but also know that too many people wait same like me, and I understand that, so can I use this fix and try alone to resolve my problems? On my PC I have full SDK and USB drivers installed, should I uninstall everything? And, if this " fix" don't work for me, can I after this revert back to CM and how? We've wait for this long time,
    Thanks to OP, thanks to you very much...
    NexusJonez, taldeital and ionut123 like this.
  12. rarog
    Go here: http://www.cmxlog.com/12.1/bacon/
    Look out for this: "synaptics: Use per-panel firmware loading (android_kernel_oneplus_msm8974)". ;)
    It's the 6th entry.
    TeaRex, redvil and DaxNagtegaal like this.
  13. rarog
    You can always change the ROMs. I'm not sure where exactly to look for this, but there have to be plenty of tutorials here in the forums like "back to stock" or "how to flash". They are more or less the same.
    Jonas likes this.
  14. DaxNagtegaal
    Marshmallow Jun 2, 2015
    DaxNagtegaal , Jun 2, 2015 :
    Do you know if it's possible to get that fix on other roms without the use of a custom kernel? Probably not eh.. I hope custom roms will start implementing it fast, I need it :p
  15. KforHorizon
    KitKat Jun 2, 2015
    KforHorizon , Jun 2, 2015 :
    Im happy !
    But I'll just wait for it to be ported in cm nightly's and then other roms ! :p
    Good to know that you guys actually fixed it!
    My issue isn't so bad now..so I'll wait!
  16. marek.zambor
    Froyo Jun 2, 2015
    marek.zambor , Jun 2, 2015 :
    Thank you opo team. This update/fix help me. Now scrolling is very fast and writing is very accurate!
    NexusJonez and KforHorizon like this.
  17. KforHorizon
    KitKat Jun 2, 2015
    You have the newest update running on your phone?
  18. rarog
    You said it yourself, either use custom kernel or wait for the ROM builder to merge the change. ;)
    It's already there. ;)
    #38
    DaxNagtegaal likes this.
  19. DaxNagtegaal
    Thought so.
    Battery drain is fixed on this firmware version? Last one was very bad.
    #39
    Ceasedd likes this.
  20. nicky3
    Froyo Jun 2, 2015
    Which recovery is installed inside in this fix??
    Or, better to flash TWRP first, before I start with installation?
    Because I'm full stock, COS12...
    #40
