61
Touchscreen issues - Fix
Please do vote so that we can check the number of Fixes as well :)
  1. Yes my touch screen issues are Fixed :)
    326 vote(s)
    43.0%
  2. No, I am still facing touch issues after following the steps :(
    432 vote(s)
    57.0%
  1. rarog
    Assistant Head Moderator Assistant Head Moderator Jun 2, 2015
    rarog , Jun 2, 2015 :
    Haven't read many reviews yet. The gerrit comments and one user from German forums say, that they didn't notice any drain.
    I'd recommend to get the newest TWRP. But don't forget to backup all you data you need, when you unlock the bootloader (which is necessary to flash different ROMs) the Data is deleted because of security reasons.
    #41
    be.sandeepgupta and DaxNagtegaal like this.
  2. marek.zambor
    Froyo Jun 2, 2015
    marek.zambor , Jun 2, 2015 :
    Yes. New update from first page. Very easy install...
    #42
  3. nicky3
    Froyo Jun 2, 2015
    nicky3 , Jun 2, 2015 :
    Thanks
    My bootloader is already unlocked, so first I will flash TWRP and then run this fix.
    Thanks again
    #43
  4. KforHorizon
    KitKat Jun 2, 2015
    KforHorizon , Jun 2, 2015 :
    Lol okay! Good to know that its easy to install! :p
    #44
    marek.zambor likes this.
  5. siroshps
    Cupcake Jun 2, 2015
    siroshps , Jun 2, 2015 :
    Todays CM 12 Nightly have the fix for ghost touch
    #45
  6. nicky3
    Froyo Jun 2, 2015
    #46
  7. NathDerbyshire
    Gingerbread Jun 2, 2015
    NathDerbyshire , Jun 2, 2015 :
    I've just downloaded with no problems I'd just ignore it it might be because drivers are in with the zip
    #47
  8. Sanam S
    Sanam S , Jun 2, 2015 :
    That is because it has DLL for the drivers and it is avery big zip file with DLL. This is totally normal :)
    #48
    PRK.R, sp99 and RonaldM like this.
  9. Subrahmanya Bhat
    Subrahmanya Bhat , Jun 2, 2015 :
    Any added features in this build? I loved OxugenOS' smoothness but then lack of features took me back to COS12.
    #49
    NexusJonez likes this.
  10. karthi89
    Froyo Jun 2, 2015
    karthi89 , Jun 2, 2015 :
    Hi,
    Does this fix(Synaptics firmware) is different form what it has already been merged in the cm12.1 nightlies dated 02-06-2015? And if its is new, are you planning to release the same to cyanogen? please let us know.
    #50
  11. NathDerbyshire
    I can confirm this fixed worked for me but I still don't understand how Oxygen is still on 5.0.2... I hope they send out updates quicker in future it's been ages now! Oh well at least I can type again.
    #51
    Hjalpmovie and marek.zambor like this.
  12. andrelages
    #52
  13. daedal
    daedal , Jun 2, 2015 :
    just follow step by step instructions provided by OP.
    I won't install until I find out is this same old (and only) OxygenOS or is it patched with something more than screen firmware...
    #53
  14. andrelages
    andrelages , Jun 2, 2015 :
    If I do that, won't it remove TWRP?
    #54
  15. Superpully
    Ice Cream Sandwich Jun 2, 2015
    Superpully , Jun 2, 2015 :
    It is just firmware? There are no chages from old Oxy? Otherwise I will keep my nightly...
    #55
  16. daedal
    it probably will. however, nothing stops you from pushing it back via fastboot once you install Oxygen ;)
    #56
    andrelages likes this.
  17. rarog
    Both use the same driver. Here the Build is form May 27th, Cyanogen lists the drivers since May 29th in Gerrit.
    #57
    RonaldM likes this.
  18. ChrisTerp
    Lollipop Jun 2, 2015
    ChrisTerp , Jun 2, 2015 :
    Is there going to be an OTA for folks that aren't techies or root?
    COS12 OTA update solution as well please.
    #58
    cwalker2015 and K.P. Smith like this.
  19. karthi89
    Froyo Jun 2, 2015
    Cool. Thanks for the response. other than the Synaptics firmware are there any changes in the fix for fixing the touchscreen issue?
    #59
  20. Manzanar
    Froyo Jun 2, 2015
    Manzanar , Jun 2, 2015 :
    Any ota news on this problem for indian uders? Not a techie here thanka
    #60
