7
Display Touchscreen issues on the edges? Software problem?
  1. ValerioMonta
    Donut Oct 22, 2020
    ValerioMonta , Oct 22, 2020 :
    Hello I am having a problem with the touchscreen: if I touch the edges of the screen it doesnt register the touch (https://streamable.com/xh2951)
    But I've also noticed that the bottom part of the screen works as it's supposed to do (https://streamable.com/cqdphx) and also that, if I rotate the screen (on chrome for example), when the app is vertical the touch works as it's supposed to do, WHILE when it's horizontal the touch stops working again near the edges: >>> https://streamable.com/kc6vr1 <<<
    So I assume this a software problem, right? (Such as a palm rejection feature or smthing to avoid supposed wrong touches?)
    The problem is that this is terrible for me, mostly ingame and with some apps, so, is there anything I can do?
    (Considering that my OP5 has no problem of this sort and I've upgraded to 8T to get a better experience in games...)
    Thx in advance for any help... :(
    okd4, thelittlelows, marzaise and 4 others like this.
  2. DaGeekWolf
    Cupcake Oct 22, 2020
    DaGeekWolf , Oct 22, 2020 :
    Hello,
    I have the same problems. Both side are not sensible to single touches. Indeed if you start moving the finger, it starts to track the movement. My impression is that it's some kind of protection for curved screen, to avoid accidental touches, that is messing around the experience.
    It's even worse in the lower corners, because here also acts google assistant, and it can do an imposible thing to send an audio message thru WhatsApp while you are using gestures navigation.
    All this seems software thing though
    bpaterson and SultanaDaaku like this.
  3. K1570888171859
    Cupcake Nov 4, 2020
    bpaterson likes this.
  4. kennethyha
    Gingerbread Dec 1, 2020
    kennethyha , Dec 1, 2020 :
    I agree, OnePlus should make palm rejection a feature and not force it on OnePlus 8T which doesn't have curved screen. I noticed it sometimes when tapping close in page ads at the corner.
  5. Bittoo06
    Jelly Bean Dec 1, 2020
  6. Rjt_Kumar
  7. kennethyha
    Gingerbread Dec 2, 2020
    kennethyha , Dec 2, 2020 :
    Hopefully
    Same here
  8. MarinosXx
    MarinosXx , via OnePlus 8T , Dec 2, 2020 :
    The 8T does not have curved screens.
  9. DaGeekWolf
    Cupcake Dec 2, 2020
  10. MarinosXx
    Gingerbread Dec 3, 2020
    MarinosXx , via OnePlus 8T , Dec 3, 2020 :
    Yes i agree but what about the fact that touch is not registered at the bottom corners of the screen?
  11. #11
  12. Everyth1ng
    Cupcake Dec 20, 2020
  13. Xpress0
    Gingerbread Dec 20, 2020
  14. Piotr Backiel
    Eclair Dec 21, 2020
  15. P1608826442949
    Cupcake Dec 24, 2020
  16. tarheel2344
    Donut Dec 24, 2020
  17. KukSu
    Donut Jan 13, 2021
    KukSu , Jan 13, 2021 :
    Same here. Really frustrating. I'm missing "a"s really often and touches are laggy at the edges. Also hard to send voice messages in telegram or whatsapp. I'd like to disable the whole edge rejection in 8T. This is almost unusable atm.
  18. Racer11
    Eclair May 26, 2021
    Racer11 , May 26, 2021 :
    Did this ever get fixed?
  19. #19
  20. marzaise
    Eclair Jun 22, 2021
    Gor.V likes this.
