2
Touchscreen sensibility problems
  1. Aiur
    Honeycomb Oct 15, 2015
    Aiur , Oct 15, 2015 :
    Since 2.1, some of us have problems with the touchscreen.
    Should i return the phone? Or wait the software fix? This is so annoying and random bug.
    EDIT 7 days after original post:
    I think that i found a "solution": Downgrade to 2.0.2, from 2.1 to 2.1.1 the phone lags like hell for me, it's impossible to write with the keyboard as you can see in this video.
    I downloaded it from here:
    https://forums.oneplus.net/threads/mirrors-for-official-oxygen-os-roms-and-ota-updates.387615/
    Exactly is this:
    Oxygen OS 2.0.2: OnePlus2Oxygen_14_OTA_006_all_1508211811.zip
    ng2000 and souvikdas95 like this.
  2. xandery
    Cupcake Oct 19, 2015
    xandery , Oct 19, 2015 :
    Having the exact same problems with my new OPT, really unimpressed, haven't manged to find a fix yet. Anyone can help?
  3. abaksh
    Eclair Oct 19, 2015
    abaksh , Oct 19, 2015 :
    I am having the same problem. It reminds me of the same problem that the oneplus one had.
    I hope they release a fix soon.
  4. Tokolozi
    Marshmallow Oct 19, 2015
  5. X1y3y2
    Gingerbread Oct 20, 2015
    X1y3y2 , Oct 20, 2015 :
    its keyboard and everything else but i think its fix after you lock and unlock again.. but it come back soon after
  6. Pravat368
    Cupcake Oct 20, 2015
  7. Aiur
    Honeycomb Oct 20, 2015
    Aiur , Oct 20, 2015 :
    Someone tried to back to 2.0 for see if this is a problem only in the 2.1 version?
  8. X1y3y2
    I flashed to another rom and the problem still exists. I am running out of options to fix this and i tried almost everything other people suggested
  9. Aiur
    :confused:
    Do you think that is a hardware issue? Is very strange because sometimes the phone works fine, and others no... It's a "random bug" at least for me...
  10. MiguelPlus
    Froyo Oct 20, 2015
    MiguelPlus , Oct 20, 2015 :
    Guys, I want you all to check something. If what I say is correct, we all have the same problem.
    - Charging the device reduces or completely resolves the touchscreen issues. (untill you stop charging)
    - The battery saver is not working the way it should (you probably don't notice it)
    How to check this? Download a benchmark app (I used antutu) and run it with battery saving off, and once more with battery saver on. If the score is higher when your battery saver is on, it means that your battery saver is reversed.
  11. Tokolozi
    Marshmallow Oct 20, 2015
    Tokolozi , Oct 20, 2015 :
    That's software then, i have AK kernel and don't have this problem.
  12. MiguelPlus
    Froyo Oct 20, 2015
    @Aiur @X1y3y2 @abaksh @xandery
    I posted this a few days ago:
    I know benchmarks (AnTuTu) are not always that accurate, however... The difference is too big to ignore. Not only is there a serious drop in performance, I also noticed unresponsive touchscreen. I guess these problems can be related. Charging the phone helps reducing the lag.
    First Oneplus2: tweaked from friend.
    Second Oneplus2: normal from other friend.
    Third Oneplus2: Mine :(
    I have not seen a similar post with this issue, am I the only one?
    A few days later I noticed that my score was equal to the normal Oneplus2 when battery saver was turned on, while his was turned off.
  13. Aiur
    I'm charging the phone now, and it appear that it work fine :)
  14. X1y3y2
    But in the other post, the guy said he had ak kernel and still lags.. I guess I will have to try it myself to find out.
    Tokolozi likes this.
  15. X1y3y2
    but you cant plug your phone in all day :(
  16. Tokolozi
    Well seems like different persons are having different problems.
  17. X1y3y2
    Did u have problem and ak kernel fix it?
  18. Tokolozi
    been running AK for a long while now and my phone was pretty much problemless from the beginning.
  19. X1y3y2
    you are lucky!
  20. MiguelPlus
    Froyo Oct 20, 2015
    I have a remote session with oneplus tech team, friday at 3PM CET. I'll let you guys know how it goes.
