2
Touchscreen sensibility problems
  1. TlathamXmahtalT
    KitKat Nov 14, 2015
    @ds likes this.
  2. makchaudhary
    Ice Cream Sandwich Nov 14, 2015
    makchaudhary , Nov 14, 2015 :
    Told you....wait for the update ...it is a s/w issue :p
    Now wait much longer :p
  3. souvikdas95
    souvikdas95 , Nov 14, 2015 :
    not really. i still have grounding problem with op2 touchscreen - triggered while charging though - occurs even during recovery mode - screen literally hangs though off-screen buttons work
  4. @ds
    Honeycomb Nov 14, 2015
  5. egorian
    Gingerbread Nov 14, 2015
    egorian , Nov 14, 2015 :
    Hi! No, you can do it without losing anything. Just don't mess with the Wiping options on the Recovery Mode.
  6. @ds
    @ds , Nov 14, 2015 :
    Thanks man, appreciate it :)
    egorian likes this.
  7. @ds
    One more question, did you receive update or u used zip?
  8. egorian
    Used the zip method. I was at 2.0.2 because of the touchscreen issue and manually flashed OTA 2.0.2 to 2.1, then OTA 2.1 to 2.1.1 and finally OTA 2.1.1 to 2.1.2. I could dirty flash directly the 2.1.1 and then applied the 2.1.1 to 2.1.2 but I was trying to save some bandwidth.
  9. @ds
    Thx :)
  10. X1y3y2
    X1y3y2 , Nov 14, 2015 :
    Did it fix the touch issue??
  11. xandery
    Cupcake Nov 15, 2015
    xandery , Nov 15, 2015 :
    The OTA download on the thread is past download limit, anyone got a link?
  12. egorian
    Gingerbread Nov 15, 2015
  13. X1y3y2
    X1y3y2 , Nov 15, 2015 :
    Nice I'm going to try it then ..thanks :)
  14. ianchen32
    @ds likes this.
  15. @ds
    Honeycomb Nov 15, 2015
    @ds , Nov 15, 2015 :
    Well, I did not either, and zip download is not working, so more waiting :)
  16. Aiur
    Aiur , Nov 15, 2015 :
    At least for me, yes. :)
    makchaudhary likes this.
  17. MiguelPlus
    Froyo Nov 15, 2015
    MiguelPlus , Nov 15, 2015 :
    Sometimes, if you have manually flashed an OTA or ROM. It's possible that futur updates won't appear.. I had this at first. The only way to get the update (in my case) was to do a factory reset. This somehow triggered the update.
  18. egorian
    Gingerbread Nov 17, 2015
    egorian , Nov 17, 2015 :
    Do you have any news from One Plus support about your OPT?
  19. MiguelPlus
    Froyo Nov 21, 2015
    MiguelPlus , Nov 21, 2015 :
    Well, monday I'll finally receive the replacement.
  20. egorian
    Gingerbread Nov 21, 2015
    egorian , Nov 21, 2015 :
    are you going to try 2.1.1 on the replacement to see if it was a SW or HW issue?
