2
Touchscreen sensibility problems
  1. imsimon
    Cupcake Oct 25, 2015
    #81
  2. MiguelPlus
    Froyo Oct 25, 2015
    MiguelPlus , Oct 25, 2015 :
    Update: still waiting for an email informing me about getting a replacement device :/ Seems to be very bussy in oneplus
    #82
  3. Aiur
    Honeycomb Oct 25, 2015
    Aiur , Oct 25, 2015 :
    If phone works fine in 2.0.2 is a software problem obviously. Anyway good luck with the new device :)
    OnePlus have an inexistent support team. I bought a OPO and wait 3 months for my money back.
    #83
  4. makchaudhary
    Ice Cream Sandwich Oct 25, 2015
    makchaudhary , Oct 25, 2015 :
    I found something related to build.prop...if you are rooted..you can try.
    I am running 2.1.1 and lag is minimal now...80 to 90% gone.
    #84
  5. Aiur
    A new kernel? :rolleyes:
    #85
  6. makchaudhary
    nopes...i have added some lines in build.prop and also using non-stock kernel....now dont have so much lag....only 2/10 times i am facing this lag issue.
    And also it proves that it is totally S/W part.
    #86
    joneightyfour likes this.
  7. makchaudhary
    windowsmgr.max_events_per_sec=90
    ro.max.fling_velocity=12000
    ro.min.fling_velocity=8000
    ro.min_pointer_dur=8
    persist.sys.scrollingcache=3
    debug.sf.hw=1
    Add these lines in build.prop and see the difference
    #87
  8. Aiur
    With 2.1.1?
    Im perfect with 2.0.2
    #88
  9. imsimon
    Cupcake Oct 26, 2015
    imsimon , Oct 26, 2015 :
    May I know your model of OP2?
    Mine is ONE A2001
    I really looking forward for the support regarding this bug fix from OnePlus support as I got suck in google map and TED as well with 2.0.2
    #89
  10. makchaudhary
    Ice Cream Sandwich Oct 26, 2015
    #90
  11. imsimon
    Noted and thks. I just struggling whether it is model issue or not (A2001, A2003, A2005)
    #91
  12. MiguelPlus
    Froyo Oct 27, 2015
    MiguelPlus , Oct 27, 2015 :
    Maybe it's hardware and software related you know? Because the same update can cause lag in one device and none in another device. So the problem was always there, but only got visible in the latest update. This would explain why oneplus send faulty devices, because they simply didn't know there was a problem YET.
    #92
  13. MiguelPlus
    Froyo Oct 28, 2015
    #93
  14. Aiur
    Honeycomb Oct 28, 2015
    #94
  15. MiguelPlus
    Froyo Oct 28, 2015
    MiguelPlus , Oct 28, 2015 :
    I know how to do those things, I just wonder if it would actually fix the problem for good. However, They'll be here anytime soom to pick up my phone so I'm not going to do it unless my replacement has the same problem. (hopefully not....)
    #95
  16. makchaudhary
    Ice Cream Sandwich Oct 28, 2015
    makchaudhary , Oct 28, 2015 :
    Best of Luck for your replacement.....i will wait till next 2 updates....if things dont go normal....then i vl go to service centre.
    #96
    MiguelPlus likes this.
  17. emilio.garza
    Cupcake Oct 28, 2015
    emilio.garza , Oct 28, 2015 :
    I have the same situation, mine is OPT A2005
    Rollback 2.0.2 is the only solution?
    Anyone tried cyanogen?
    #97
  18. fkur2943
    fkur2943 , Oct 28, 2015 :
    For those who still suffers touchscreen issue, here is the fix (at least for me)
    Unlock bootloader,
    Install Root
    install TWRP
    Right now I am running Resurrection Remix Lolipop 5.1.1 r24. So far, much better than the stock Oxygen.
    Fixes the touch screen issue,
    more customization,
    Amazing battery life,
    home button works,
    however, the fingerprint does not,
    laser auto focus works.
    http://forum.xda-developers.com/oneplus-2/development/rom-resurrection-remix-t3208988
    Let me know if this works : )
    #98
  19. MiguelPlus
    Froyo Oct 29, 2015
    MiguelPlus , Oct 29, 2015 :
    So I was bored and ehm, I tried to find a fix on my own.. Problems are totally gone for the past hour. Only thing I did was flash stock 2.0, after that I did a factory reset, and after that I updated to 2.1.1. This is awkward because I'm supposed to send it back ;d
    #99
  20. emilio.garza
    Cupcake Oct 29, 2015
    emilio.garza , Oct 29, 2015 :
    I tested when is charging and the problem goes away... How is that? unplugged gets laggy but when charging there is no lag or touchscreen issues!
