2
Touchscreen sensibility problems
  1. MiguelPlus
    Froyo Nov 1, 2015
    MiguelPlus , Nov 1, 2015 :
    https://forums.oneplus.net/threads/mirrors-for-official-oxygen-os-roms-and-ota-updates.387615/
    that's where you could find this: https://www.androidfilehost.com/?fid=24052804347821051
    You just download the file, put it (for example) in download map of your phone. Then go into recovery mode and flash the file you downloaded.
    egorian likes this.
  2. iainchan97
    Donut Nov 2, 2015
  3. makchaudhary
    Ice Cream Sandwich Nov 2, 2015
  4. iainchan97
    Donut Nov 2, 2015
    iainchan97 , Nov 2, 2015 :
    I just got it done, and it works perfectly! Oxygen OS 2.0.2 no touchscreen issues so far. Software related issue for me. Thanks!
    makchaudhary likes this.
  5. MiguelPlus
    Froyo Nov 2, 2015
  6. iainchan97
    Donut Nov 2, 2015
    Hahaha idk what you pressed, but I didn't lose any data hahah
    MiguelPlus likes this.
  7. makchaudhary
    makchaudhary , Nov 2, 2015 :
    hahahaha...when you press ...wipe cache and data...again press wipe cache...then reboot.
    May be you did press ....wipe cache and data...2 times...which leads to del your all data :D
    No probs...your sacrifice will not waste. OnePlus will provide you a worthy update soon :D :D :p :p
  8. MiguelPlus
    Froyo Nov 2, 2015
    MiguelPlus , Nov 2, 2015 :
    No they will get me a replacement in the next few days :p my old one is being inspected as we speak!
  9. makchaudhary
    GR8....i am waiting for the update...if doesnt fix...will go to the Service Centre.
  10. MiguelPlus
    Froyo Nov 2, 2015
    Oh you live near that place?
  11. makchaudhary
    Yes..OnePlus has service centres in India.
    One of them is nearby my Office...walking distance...hardly 10 mints. ;)
  12. MiguelPlus
    Froyo Nov 2, 2015
  13. makchaudhary
    hahaha :D no worries ...your fone is on the way ;)
  14. @ds
    Honeycomb Nov 2, 2015
    @ds , Nov 2, 2015 :
    guys, just quick one, apart from touch screen issue, my a2003 scores very different in antutu, last Friday, approx 40k, Saturday approx 50k today again 40k, anyone experienced something similar?
  15. MiguelPlus
    Froyo Nov 2, 2015
    Antutu benchmark scores are completely useless. I actually did some research for that matter. My scores could range from 40k till 60k. Your oneplus device is actually smart enough to decide if it really should use that much power and heat up the phone for no good reason. So yeah, nothing to worry about.
  16. MiguelPlus
    Froyo Nov 2, 2015
    This is why I got confused but after all, it doesn't make a difference, because they tried again later and the scores were totally different.
    I know benchmarks (AnTuTu) are not always that accurate, however... The difference is too big to ignore. Not only is there a serious drop in performance, I also noticed unresponsive touchscreen. I guess these problems can be related. Charging the phone helps reducing the lag.
    First Oneplus2: tweaked from friend.
    Second Oneplus2: normal from other friend.
    Third Oneplus2: Mine :(
  17. @ds
    @ds , Nov 2, 2015 :
  18. Aiur
    Honeycomb Nov 3, 2015
    Aiur , Nov 3, 2015 :
    I'm waiting for next update too. I hope they fix it.
    makchaudhary and sergiotp like this.
  19. sergiotp
    Gingerbread Nov 3, 2015
    sergiotp , Nov 3, 2015 :
    I'm waiting the same... :mad::mad::mad::mad::mad:
  20. Aiur
    Honeycomb Nov 5, 2015
    Aiur , Nov 5, 2015 :
    1 month more or less since i recieved the phone. No solution for this annoying problem for the moment... Thx Oneplus for your support.
    I have one invite for the OnePlus X, i was thinking to buy it for my girlfriend, but watching this i think that better go to another brand :)
