Transparent navigation bar required on oxygen os! via OnePlus 7T
  1. Amandeep_8129
    Froyo Aug 1, 2021
    Amandeep_8129 , via OnePlus 7T , Aug 1, 2021 :
    Hello ,
    OnePlus should do something with its navigation bar ... The ui of apps are very inconsistent and the navigation bar itself takes other place on bottom with a white / black strip behind it which looks ugly. Kindly, make the navigation bar transparent so that it 'FLOATS' on apps , not takes extra space at bottom
  2. Sheppards
    Jelly Bean Aug 1, 2021
  3. ChiragR787
    Eclair Aug 1, 2021
    ChiragR787 , via OnePlus 7T Pro , Aug 1, 2021 :
    on OnePlus nord 2 they fixed it
    it now hovers over text and don't take any extra space
    Amandeep_8129 likes this.
  4. RedStamina
    Froyo Aug 12, 2021
    RedStamina , via OnePlus 8 Pro , Aug 12, 2021 :
    U think it'll come to other OnePlus devices via an software update?
  5. ChiragR787
    Eclair Aug 14, 2021
  6. Drasm19
    Ice Cream Sandwich Aug 14, 2021
    Drasm19 , Aug 14, 2021 :
    OOS 12 will take ages to grace OP7T.
  7. ChiragR787
    Eclair Aug 14, 2021
    ChiragR787 , via OnePlus 7T Pro , Aug 14, 2021 :
    Yeah but there's nothing we can do
    and I don't know any custom rom that has navigation bar that hovers like on ios.
  8. ghostofcain
    Marshmallow Aug 14, 2021
    ghostofcain , Aug 14, 2021 :
    Why are you using a navigation bar in the first place? Gestures work fine.
    Drasm19 likes this.
  9. ChiragR787
    Eclair Aug 14, 2021
    Yeah i am telling about that small bar while using gestures at bottom of screen
    it takes unecessary space
    see ios devices it is on top of everything and don't take space
  10. Drasm19
    Ice Cream Sandwich Aug 15, 2021
    Drasm19 , Aug 15, 2021 :
    You can always disable it. I've have it disabled on my device.
