2
Trouble in ultra fast charging taking almost 1hour 20min to Charge from 0 %to 100% via OnePlus 8T
  1. D1512320483047
    Cupcake Nov 6, 2020
    Md.Asif786 and Tirathfaldu98 like this.
  2. Rajendra.Bhat
    Jelly Bean Nov 6, 2020
  3. Shailender Sharma
    Marshmallow Nov 6, 2020
    Shailender Sharma , Nov 6, 2020 :
    It should charge in 40 minutes. Are you using the original warp 65 charger and cable for charging?
  4. D1512320483047
    Cupcake Nov 6, 2020
  5. Rajendra.Bhat
    Rajendra.Bhat , Nov 6, 2020 :
    Factory reset and update to latest os available. If you still face the issue visit service center
  6. D1512320483047
    Cupcake Nov 6, 2020
  7. V1573199788432
    Donut Nov 6, 2020
  8. AlienEye
    OnePlus Accessory Tester Nov 6, 2020
  9. Rjt_Kumar
    Gingerbread Nov 6, 2020
    Rjt_Kumar , via OnePlus 8T , Nov 6, 2020 :
    Factory reset is not always the solution... Dont give this suggestion all the time for all issues rather reply with proper solution (if have)... Factory reset is not an easy task when you have days of data, and apps setup and configuration... if someone like me have 20's of business working apps.
    Tirathfaldu98 likes this.
  10. Rajendra.Bhat
    Ever heard of backup!?
  11. Rjt_Kumar
    Ok now for solution: drain out the battery completely, and charge the mobile from 0-100%. Make sure dont turn on the mobile untill fully charge... and record the time if mobile charges within 40min the mobile and charging brick is ok...
    39min achieved in some ideal conditions like battery temperature, room temperature, etc. I am achieving perfact charging speed in normal conditions... Although sometimes it took time because of 12 layers of circuit protection is trying to preventing the battery damage...
    Do not need to turn off the "optimize charging" option because this is helping your battery to keep safe and understanding the charging behaviour to keep battery life long.
    .. i think slow charging is better in term of battery life...
    Update: with 65 watt charging brick team OnePlus claiming that it will give you 80% battery life after 1000 charging cycles... Hope this information will help.
    D1512320483047 likes this.
  12. Rjt_Kumar
  13. Rajendra.Bhat
  14. pcoventry
    Honeycomb Nov 6, 2020
    pcoventry , Nov 6, 2020 :
    That's highly likely and you are correct slow charging does help with battery life- however slow charging creates heat so it's a moot point. I've had 50W phones for about 5 years now, Warp charge and SuperVooc etc is a better way because the heat is kept away from the phone.
    1000 cycles to 80% is good for Li-Ion chemistry. That's better than last years chem which was 500 cycles roughly. But when we start using LifeP04 in mobiles that will increase to 2000,3000 and beyond before the 80%
    Of course - doing 15-95% is better than 0-100. But then again if you did 100%>66%>100% you would increase that 1000 to about 1800. Anyway as most phones last 2-3 years before they are swapped- 1000 cycles is good enough
  15. D1512320483047
    Cupcake Nov 7, 2020
