Trying out Android 12 through DSU Loader via OnePlus 7T Pro
  1. hero2lte
    Donut May 19, 2021
    hero2lte , via OnePlus 7T Pro , May 19, 2021 :
    Has anyone tried using the DSU Loader option in developer settings to try out the new beta GSI build of Android 12?
    I have but instead of getting the installation going I get every time this notification that there was an error when installing.
    Does it work for you?
    Do you know a solution?
  2. SuperArtus
    Donut May 19, 2021
    hero2lte likes this.
  3. #3
    Gohil_Chirag and hero2lte like this.
  4. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert May 20, 2021
    Dresa91 , May 20, 2021 :
    I think there is no A12 build for OP 7 Series,…
    KluGe and Sam197 like this.
  5. hero2lte
    Donut May 21, 2021
    hero2lte , via OnePlus 7T Pro , May 21, 2021 :
    That is true.
    I'm talking about Android 12 beta 1 GSI build.
    Android 11 has a feature called Dynamic System Update Loader or DSU Loader for short. For devices released with Android 10 out of the box - that is OnePlus 7T series for example - it should allow for seamless and temporal installation of a dynamic system - next to Android 11. That is create a temporal kind of dual boot. So the phone still has Android 11 but you should be able to try out Android 12. This option is hidden in developer settings and called DSU Loader.
    The problem is - it does not work.
    I get some install error.
    My friend had it installed but it wouldn't boot. (No data has been lost)
    This article discusses the feature:
    https://www.xda-developers.com/andr...ootloader-developers-test-apps-stock-android/
    It kind of seems that people have forgotten about this option. It would be really amazing if it worked.
    northbay5566, B_Wrath and Dresa91 like this.
  6. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert May 21, 2021
    Dresa91 , May 21, 2021 :
    Think this won’t work yet
  7. SuperArtus
    Donut May 21, 2021
    Syrix likes this.
  8. KluGe
    Lollipop May 21, 2021
    KluGe , May 21, 2021 :
    People are crazy!
    And it is getting worse every day!
    Stable: OS10 :)
    Struggling with: OS11 :confused:
    And now, for the complete crazy ones: Android 12 on the 7T Pro :eek::mad:
    WHY?
  9. ninjasinabag
    Cupcake Jul 15, 2021
    ninjasinabag , Jul 15, 2021 :
    It's a test. So it only creates a temporary partition for testing the gsi. Once you reboot, it's ends the test.
    There's an adb command you can use to make it a stick over reboots though.
    Upmanyu430 likes this.
  10. Dhruv195
    Eclair Jul 17, 2021
    Dhruv195 , via OnePlus 8 , Jul 17, 2021 :
    Did it work for you? I tried installing on my OnePlus 8 but failed at reboot stage.
  11. Drasm19
    Ice Cream Sandwich Jul 17, 2021
    Drasm19 , Jul 17, 2021 :
    It will take another year from today, for the first beta build of OOS 12 to appear for OP 7T.
    Don't worry about this.
    TheBabaYaga likes this.
  12. brandontict
    Cupcake Sep 2, 2021
    brandontict , Sep 2, 2021 :
    I personally want everything I can get out of my handset ( oneplus 7t ) .
    Flashing third party firmware ( Roms, Kernels ) runs a little more smoother, responsive and much better battery, just to state a few Pros.
    Although, they're Cons as well, Some cases, More bugs :(
    The risk is worth the squeeze :-D
  13. #13
