Trying to get a nano sim card for oneplus two
  1. kc4one
    Ice Cream Sandwich Sep 19, 2015
    kc4one , Sep 19, 2015 :
    You can save it for future use or sell it
  2. turqu0isemoon
    Eclair Sep 19, 2015
  3. Tobikage
    Nougat Sep 19, 2015
    Tobikage , Sep 19, 2015 :
    Yes I did. Both SIMs fit perfectly.
    Nope....did not need anything besides a pair of scissors.
    BUT I have done this a LOT of times before....so be careful. You don't want to ruin your SIM. Better get a SIM cutter than experimenting on your working primary SIM for your first time.
  4. wayne_sony
    Honeycomb Sep 19, 2015
    wayne_sony , Sep 19, 2015 :
    I think I might as well just buy a new sim. those cutters cost about $7 and I can get a new sim from Microsoft store for $10
    Tobikage likes this.
  5. Tobikage
    Nougat Sep 19, 2015
    I'd still keep the cutter handy considering all future phones will need a nano SIM ...never know if a friend / family member might need one....might just save you some $$ in the long run.
  6. robdam1001
    Gingerbread Sep 19, 2015
    robdam1001 , Sep 19, 2015 :
    Tmobile actually charges it's customers for SIM cards?????????????? That's so wrong.
  7. CC Dude
    CC Dude , Sep 19, 2015 :
    Buy a nano sim from T-Mobile and have them provision it .
  8. chrsfrwll
    chrsfrwll , Sep 19, 2015 :
    I walked into my Vodafone shop and asked them to switch my micro from the One for a nano for the Two, which they did foc. Took about half an hour for the number to port across.
  9. kanagadeepan
    KitKat Sep 19, 2015
  10. evilone
    Jelly Bean Sep 19, 2015
    evilone , Sep 19, 2015 :
    done option 2 several times, works just fine
  11. tdark
    tdark , Sep 19, 2015 :
    I'm from India. Out here, most cell phone accessory shops have sim cutters and they charge you a very small amount for cutting your sim to any size. I got mine cut, no sanding was necessary for my sim. Working fine so far. I've been using it for about 25 days.
  12. Jawad973
  13. thboyes
    thboyes , Sep 19, 2015 :
    I cut the SIM to a micro when I got my OPO and again recently to a nano when I got my OPT. It's not very difficult as long as you have sharp scissors and a file.
  14. xzenzo
    xzenzo , Sep 19, 2015 :
    Go to your closest t mobile store and asked them to cut it for you... Carrier is Vodafone, when my opo came, i went to the store and they just clip it free of charge.
  15. Joeysheart
    Donut Sep 19, 2015
    Joeysheart , Sep 19, 2015 :
    You could go to Walmart and get the T-Mobile starter kit for $29 that includes the sim card and one month of service. Or you could order the kit online. It is for T-Mobile and not StraightTalk.
  16. Joeysheart
    Donut Sep 19, 2015
  17. Melancholie
    Melancholie , Sep 19, 2015 :
    In the UK on Three. Went into the store, said I'm on a SIM only plan and just bought a new phone which needs a nano SIM. He used a cutter on it for me free of charge, no need for sanding, then offered to buy my OPO off me when he realised what I had upgraded from/to.
  18. maniatiko
    maniatiko , Sep 19, 2015 :
    Im in MA and when i got my original phone i had a regular sim and needed a micro, went into T-Mobile and they just swapped it out for me for free. didnt need to pay anything. Also same thing with Moto X Pure. went into the store and gave them micro sim from my OPO and they gave me a nano for free. didnt pay anything. they swapped it out. and did the whole process there.
    #38
    Deactivated User likes this.
  19. Deactivated User
    Sep 19, 2015
    #39
  20. gmo8492
    Lollipop Sep 19, 2015
    gmo8492 , Sep 19, 2015 :
    It worked fine for me, I just got a sim cutter that had the best rating on Amazon. I have already cut sim cards for 5 of my friends and if its a tight fit you can use a nail filer to smooth it out. My sim cutter basically paid for itself.
    #40
