Trying to get a nano sim card for oneplus two
  1. Velkis
    Gingerbread Sep 19, 2015
    Velkis , Sep 19, 2015 :
    You can't order a sim from T-Mobile's prepaid website. They frequently sell SIMs for a dollar and free shipping. Don't know if the promo is still up.
    #41
  2. dubinsky
    Froyo Sep 19, 2015
    #42
    DoitJ1 likes this.
  3. DoitJ1
    KitKat Sep 19, 2015
    DoitJ1 , Sep 19, 2015 :
    That's a rotten list of options. I just Eagles into an ATT store, told them I needed a new one for my new phone and they inserted a free one. Bummer for you. :oops::oops::oops:
    #43
  4. wayne_sony
    Honeycomb Sep 20, 2015
    wayne_sony , Sep 20, 2015 :
    it's not up. I know they do sales occasionally. i got mine from the last sale. orders a micro sim instead of nano. should have ordered a nano and used the adapter that came with opo
    #44
  5. aenews
    KitKat Sep 20, 2015
    aenews , Sep 20, 2015 :
    They just had a 99¢ SIM promotion recently. Should have taken advantage of that but oh well. You can overpay and get one off Amazon/eBay for around $5. Last time I tried a SIM Cutter I broke the SIM. If you're more careful I've heard it isn't very super difficult.
    #45
  6. Marijuanainc
    Ice Cream Sandwich Sep 20, 2015
    Marijuanainc , Sep 20, 2015 :
    Im on the same boat. I did this yesterday with an att sim and it was well worth it. It was easy to cut and i have the form if you want it so that you can measure it correctly and cut it correctly.
    #46
  7. wayne_sony
    #47
    Mgos likes this.
  8. Marijuanainc
    cancel it. its super easy and takes 2minutes max
    #48
  9. aenews
    KitKat Sep 20, 2015
    Why would you buy a cutter from Amazon instead of the cheaper SIM!
    Also I like that T-Mobile only sells Nano SIM's now. A lot more convenient for changing devices.
    #49
    Deactivated User likes this.
  10. Mgos
    Mgos , Sep 20, 2015 :
    I have one of those sim cutters that I got for $5 on Amazon, & I use it all the time. They work just fine. I don't think you will need to sand it down to fit in the oneplus because of the way the tray works, but you will be able to tell.
    #50
    aenews likes this.
  11. Penfold84
    Froyo Sep 20, 2015
    Penfold84 , Sep 20, 2015 :
    I just cut my sim, no template or sanding just careful cutting... Took all of 45 seconds and works perfectly well.
    #51
    aenews likes this.
  12. sucker
    Gingerbread Sep 20, 2015
    sucker , Sep 20, 2015 :
    Just ended up cutting mine no template used just eyeballed it...works great.
    #52
    aenews likes this.
  13. potatolover47
    Eclair Sep 20, 2015
    potatolover47 , Sep 20, 2015 :
    Wanna hear what I think?
    Of course you do silly
    That's why you're here today
    So sit down with uncle Timmy
    Listen to my advice
    And hear what I have to say
    Buy a new nano SIM card
    And put it in your tray
    Don't risk having to pay
    For your own mistake
    WORD!!
    (but seriously tho,OP2 is hard to get, don't risk it)
    #53
    aenews likes this.
  14. Deactivated User
    Sep 20, 2015
    #54
    aenews likes this.
  15. greenbottle
    Eclair Sep 20, 2015
    greenbottle , Sep 20, 2015 :
    Yes I did but it doesn't take much. Probably just about 20 passes on a P80 to P100 grit sand paper I had laying around.
    #55
  16. Deactivated User
    Sep 20, 2015
    #56
  17. MrFingerIII
    Lollipop Sep 20, 2015
    MrFingerIII , Sep 20, 2015 :
    I know you think you got this but why ruin a sim for the nano sim not all phones will use nano sim
    It would be smarter to have both for any situation you'll understand when you get older that's all I have to say about that
    #57
  18. Iphoneadopteer
    Froyo Sep 20, 2015
    Iphoneadopteer , Sep 20, 2015 :
    Buy a nano sim cutter. Costs 9.00 or less. I used mine to convert my T-Mobile into nano sim. Otherwise, go to T-Mobile and ask for a sim. Whatever you do don't do it yourself.
    #58
  19. Papao
    KitKat Sep 20, 2015
    Papao , Sep 20, 2015 :
    option 1 cut it yourself with a scissor or a cutter, very easy.
    #59
  20. Jay_95
    Jay_95 , Sep 20, 2015 :
    T-Mobile cut my micro sim for free, so you might want to try that first. They also offered to give me a new one for free, because mine is old and outdated.
    #60
