2
Trying to get OP3 working on Verizon
  1. aenews
    KitKat Feb 9, 2017
    aenews , Feb 9, 2017 :
    OP3/OP3T supports 1X/3G over Band 0 CDMA. Areas using Band 1 (CDMA) would not have coverage. OP3/OP3T supports LTE over Band 2 and Band 4. It does not have Band 13 LTE (Verizon's Main LTE Band).
    How is AT&T/T-Mobile coverage in your area?
    #41
  2. kylesweet
    Honeycomb Feb 9, 2017
    kylesweet , Feb 9, 2017 :
    Verizon uses different "Main" LTE bands in different cities, correct?
    #42
  3. aenews
    KitKat Feb 9, 2017
    Band 13 is Verizon's primary LTE Band, but they also have a good amount of areas using Band 2 and Band 4 to various degrees.
    They generally use Band 0 (CDMA), there are a considerable number of major cities using Band 1 which wouldn't get 1X/3G.
    #43
  4. Sneakerfreak32
    Cupcake Feb 10, 2017
    Sneakerfreak32 , Feb 10, 2017 :
    I had the same thing the call would go through but my data was 3g not LTE I switched to cricket and have unlimited everything now
    #44
  5. Ricky101RK
    Donut Feb 10, 2017
    #45
    aenews likes this.
  6. aenews
    KitKat Feb 11, 2017
    aenews , Feb 11, 2017 :
    In general, calls will never be on LTE on any carrier unless VoLTE is enabled on both the device and carrier. That would have been normal for most devices a couple years ago.
    When using Verizon on the OP3, there seems to be an issue switching between 3G (CDMA) and LTE. So it's to be expected.
    #46
