9
Tudia Case
  1. Salmonfish
    KitKat Aug 12, 2014
    Salmonfish , Aug 12, 2014 :
    http://www.amazon.com/TUDIA-Bumper-...=1407814077&sr=8-1&keywords=one plus one case
    I preordered this case hoping for luck (I'm usually lucky with Amazon purchases)
    and thought that if it wasn't good then I'd return it for something else.
    But now I'm so glad I got this phone because it manages to tightly grip the phone and has a slim smooth matte kind of finish almost all across the back of the phone. The TPU seems soft enough and I am simply loving it
    I also had the guts to put my OPO and the Tudia to the test on pavement from my waist (half of 5 feet 7) and I was satisfied to fine that my OPO was fine and no scratches were found on the case
    mjgnn6, essenin, epresnell1 and 6 others like this.
  2. Graham_w_94
    Ice Cream Sandwich Aug 12, 2014
    Graham_w_94 , Aug 12, 2014 :
    Looks nice, and snug fit... plus doesn't look like it adds alot of weight/size to it...
  3. Salmonfish
    KitKat Aug 12, 2014
    Oh it still weighs the same to me...its not a lot of weight but its sturdy...plus theres a lip so i can finally place my phone down front
  4. srsfknbzns
    Salmonfish likes this.
  5. Graham_w_94
    Compatible with a Tempered protector? (like doesn't push it up?) the lip is good, especially for protection and with a tempered its even better,
  6. Salmonfish
    KitKat Aug 12, 2014
    yup it works fine with my tempered glass protector
  7. Skf123
    Marshmallow Aug 12, 2014
  8. Salmonfish
    KitKat Aug 12, 2014
    IKR...so minimalistic but so great...they didn't start making them until August 4th so I had to place my bet that it would be good (PS- they also gave me a letter thanking them for believing in them before reviews came out :))
  9. Salmonfish
    KitKat Aug 12, 2014
    NOPE....
    can't take a pic of it right now sry :)
  10. Skf123
    Skf123 , Aug 12, 2014 :
    Its cool i was just checking out pics/videos of it and they all say it is slim. Unfortunately it's not available in the UK i can only get it on amazon shipped from the US
  11. Salmonfish
    KitKat Aug 12, 2014
    then get the Diztronic...both are great :)
    I had Diztronic but opted for this one because I didn't like the red Diztronic I got
    Skf123 likes this.
  12. Skf123
    Funnily enough the tudia actually works out cheaper than the diztronic even though the latter is shipped from UK lol not sure why.
    Why didn't you like the diztronic was it just the colour? Which one feels thinner and better in the hand (grip etc)
  13. Salmonfish
    KitKat Aug 12, 2014
    to me....the Tudia was a lot more grippable because of the two glossy, slightly rubbery parts to the back on the bottom and top (see pictures)
    the diztronic is all slippery matte (not that slippery both are good) but i just liked that grippy rubber part a bit better on the Tudia...
    Im not a Tudia spokesperson :) just giving my opinion
    Go for the cheaper of the two if they aren't the same...both are amazing
    PowerLemons and Skf123 like this.
  14. Skf123
    The Tudia sounds better to me so will probably go for that
  15. binky
    Lollipop Aug 12, 2014
    binky , Aug 12, 2014 :
    The Tudia does seem more sturdy than the Diztronic. Perhaps a bit more bulky, but I feel fairly confident it can protect a phone from a 5 foot drop onto a flat surface...the Diztronic not so much.
  16. oupavoc
    Froyo Aug 12, 2014
  17. Salmonfish
    KitKat Aug 12, 2014
    IKR....did you order it after the 4th or before :)
    I ordered before the 4th so was risking a lot of time and money
    glad i made the choice
  18. epresnell1
    Honeycomb Aug 12, 2014
    epresnell1 , Aug 12, 2014 :
    I have the Diztronic black matte and the Tudia both, same size and weight. With the Diztronic you can hardly tell you have a case on the phone but the Tudia looks pretty good on it.
  19. Salmonfish
    KitKat Aug 12, 2014
    mhm...which do you prefer though?
  20. oupavoc
    Froyo Aug 12, 2014
    oupavoc , Aug 12, 2014 :
    After the 4th!
