Tudia Slim Fit Dual Layer issue
  1. Flywhiz101
    Ice Cream Sandwich Dec 16, 2014
    Flywhiz101 , Dec 16, 2014 :
    Howdy yall,
    I just got Dual Layer case today. I like it, like a lot, but there is one thing that really really bugs me.
    The power button is extremely sensitive, so that I could just brush my hand against it and it would turn on. Heck, I bet if I blew on it hard enough, it would turn on, (that's what she said). Anyone have any fixes for this?
  2. Ycantibeu21
    Jelly Bean Dec 16, 2014
  3. Flywhiz101
  4. mwayner
    Lollipop Dec 16, 2014
    mwayner , Dec 16, 2014 :
    Yup. Either return it or do like I did: place three layers of clear scotch tape on either side of the power and volume buttons. Also, check that the edges of the cutouts aren't rubbing against the buttons. I dubbed mine the Tudia Ultra-Tight because my problems were even worse than yours; lockups and apparently random reboots, to mention a couple.
  5. 9843823790849
  6. mwayner
    From Amazon. It's been fine since I made the 'mods'.
  7. 9843823790849
  8. mwayner
    Can't remember. It was a couple months ago. I'll check later.
  9. Flywhiz101
    the scotch tape would make the buttons more responsive, ive done it on other cases. Are you sure?
  10. slpkn
    slpkn , Dec 16, 2014 :
    I think he means putting the tape next to the button on both sides not on top.
  11. Flywhiz101
    that makes more sense
  12. mwayner
    ^^ What he said. :)
  13. AndyPober
    AndyPober , Dec 16, 2014 :
    Did you put it on with both parts together or one layer at a time? The correct procedure is to put both parts together and then slip the whole thing onto the phone. Start at the bottom. You may have an alignment problem. Works fine for me.
