Tuto call recording android 9
  1. ascrounch
    Donut Nov 13, 2019
    ascrounch , Nov 13, 2019 :
    hi !
    1- dowlaod ADB here : (or elsewhere)
    https://dl.google.com/android/repository/platform-tools-latest-windows.zip
    2- activate USB debugging into the phone (developpers's hidden mode)
    3- plug the phone on the PC. On the phone, a message appears asking you to accept the connection. answer YES
    4- on your computer, (with CMD ) launch ADB ,
    Open the folder that you installed the ADB tools in and open the platform-tools folder. This is where the ADB program is stored. Hold Shift and right-click inside the folder. Choose “Open Command Window Here”.
    then write theses 2 lines :
    4a : adb devices (your phone should be list)
    4b : adb shell settings put global op_voice_recording_supported_by_mcc 1
    5- finish !
    Horsault likes this.
  2. Kafi.bd
    Donut Nov 13, 2019
  3. ascrounch
    Donut Nov 13, 2019
  4. Horsault
    Marshmallow Moderator Nov 13, 2019
  5. ascrounch
    Donut Nov 13, 2019
  6. Lupastro82
    Gingerbread Nov 17, 2019
    Lupastro82 , Nov 17, 2019 :
    Yes but... Lost on reboot.
    I've, in Android 10 stable and op6, permanent auto recorder thanks to joneplustool and work so good :)
  7. Kafi.bd
    Donut Nov 17, 2019
    Kafi.bd , via OnePlus 6 , Nov 17, 2019 :
    Android 10 stable? which country?
  8. Lupastro82
  9. Kafi.bd
    Donut Nov 25, 2019
    Kafi.bd , Nov 25, 2019 :
    Thanks to @ascrounch for this tutorial. It works. But, when i dial a number and it starts to call the number, the recording vanishes. Any solution?
    by the way, here is screenshot of writing the command!
