Tutorial: How to Get 4k 60FPS on Oneplus Nord Rear Camera via OnePlus Nord Blue Marble
  1. JjamoTvHD , via OnePlus Nord Blue Marble , Aug 4, 2020 :
    So, you already know why you're here...
    You've got the Nord, and you've got 4k60 on the front camera... But only 4k30 on the rear camera... (wtf oneplus?!)
    Well, long story short, you can get 4k60 on the rear camera by using The Pixel 4 Gcam software for NORD :D
    This forces the phone to shoot 4k60... Guide below.
    Go to this Apk website:
    https://www.celsoazevedo.com/files/android/p/google-camera-oneplus-nord/
    Then Download the Gcam APK for Oneplus 8/8pro:
    Then open up the Gcam app once installed and open settings...
    Then scroll all the way down to the bit which says ultra high resolution video:
    You know what to do next lol - make sure it's checked and you're ready to go :D
    angielo likes this.
  2. angielo
    Honeycomb Aug 4, 2020
    T1596712435043 and JjamoTvHD like this.
  3. Last edited: Aug 4, 2020
    angielo likes this.
  4. angielo
    Honeycomb Aug 6, 2020
    JjamoTvHD likes this.
  5. tide1109
    Jelly Bean Aug 8, 2020
    tide1109 , via OnePlus 7T , Aug 8, 2020 :
    Where did you found, that the Nord supports 4k60 with GCam on the rear camera?
    That Camera API has to support the resolution and frame rate for video recording. The Nord probably doesn't offer a 4k60 option on the rear camera. Why would OnePlus remove 4k60 on their camera app and allow 4k60 on third party apps.
    They completely removed 4k60 from the device.
    GCam's 4k60 recording uses a lower bit rate on my 7T than the stock OnePlus camera. Maybe they use better coded but I think it records in less quality.
    A 10 seconds clip from GCam has a size of ~60MB, where a similar 10 seconds clip from the OnePlus Camera uses over 200MB. I selected 4k with 60fps in both apps.
    Did you tested the 4k60 video recording on your Nord? Is it really 4k with 60 fps?
    Bouncer71 likes this.
  6. JjamoTvHD , via OnePlus Nord Blue Marble , Aug 11, 2020 :
    Yeah it's coming up as 4k60 when I transfer the files to Windows. I'll do a little Video on it later on to show ya.
    I've put the link to the version of gcam I used in my post :)
    It works pretty well.
  7. RubinDublone593
    Cupcake Aug 17, 2021
    RubinDublone593 , Aug 17, 2021 :
    Is there also a version for the OnePlus Nord 2?
