Twitter dosn't work
  1. Fran Rico
    Cupcake Sep 20, 2020
    Fran Rico , Sep 20, 2020 :
    In my OP6t the twitter application does not work. It does not upload the links or photos or videos. Can stay like this for days until you update and the same thing happens again. Someone else happens?
  2. ariblaze
    Jelly Bean Sep 20, 2020
    Fran Rico likes this.
  3. itsFreelancer
    Honeycomb Sep 21, 2020
    itsFreelancer , via OnePlus 6 , Sep 21, 2020 :
    If it's only happening with Twitter, it could be a twitter issue. Clear cache of twitter and try again. Or uninstall and reinstall the app. That would generally sort things out
  4. Fran Rico
    Cupcake Sep 21, 2020
    Fran Rico , Sep 21, 2020 :
    Happens with WiFi and data
  5. Fran Rico
    I think the same, it may be a twitter problem. I have tried clearing the cache and it keeps happening. and I had already reinstalled the application and it is not solved either. It happens to me from oxygen 10.3.5.
  6. ariblaze
    Jelly Bean Sep 21, 2020
  7. Fran Rico
    Cupcake Sep 22, 2020
  8. ariblaze
    Jelly Bean Sep 22, 2020
  9. ariblaze
  10. G_Alejandro_Beltran_OWss , via OnePlus 7T , Oct 1, 2020 :
    Hi there, I'm facing the same problem only a slight difference, in my case it only happens when I turn on the data, and it's woth the only app it happens. Already uninstalled and installed again but still facing same problem. Yet when I connect to my wifi it doesn't happen.
  11. Caomhin
    Marshmallow Oct 2, 2020
    Caomhin , via OnePlus 6T , Oct 2, 2020 :
    In the Twitter Settings under General>Data Usage, make sure that Mobile Data & Wifi is enabled under each of the sections where you want to receive Data.
    In Twitter App Info make sure Disable Data usage is not enabled
  12. Fran Rico
    Cupcake Oct 6, 2020
    Fran Rico , Oct 6, 2020 :
    I finally downloaded the stable version of twitter from September from apk mirror and so far I have not had problems.
    Thanks for your help!
    Caomhin likes this.
